Golf mk4
Wazzzer
intermittent petrol gauge
Topic: intermittent petrol gauge (Read 1497 times)
Scottymk4
Here all the time
02 October 2013, 09:53 »
Hey Guys,
First problem with my new purchase...put £30 petrol in last night gauge showed half a tank this morning half a tank again the went to empty, left it for 30 mins and looked and it was back up to half..
any ideas what would cause this?
Rhyso
Global Moderator
Sir Postalot
Re: intermittent petrol gauge
02 October 2013, 10:05 »
Sender in the fuel tank
Fire Up The Quattro
Scottymk4
Here all the time
02 October 2013, 10:08 »
thanks for the reply, is this an easy fix?
Rhyso
Global Moderator
Sir Postalot
02 October 2013, 11:15 »
Quote from: Scottymk4 on 02 October 2013, 10:08
Cant help you there sadly. Think you can access it from the boot though. Under the carpet should be a round hatch which unscrews
Fire Up The Quattro
Scottymk4
Here all the time
02 October 2013, 11:27 »
cheers anyway, anyone done this? how hard for a novice?
dom
10k hero
Back in a Mk4
As Rhyso says it's likely to be the sender which is attached to the bottom of the fuel pump. You can access the pump which is under the rear seats. I'd try giving the sender a clean as a first step, just make sure you haven't got a full tank of fuel before hand.
Scottymk4
Here all the time
Reply #6 on:
02 October 2013, 11:33 »
thanks dom, tank is half full, is this an easy job for a novice? what do you clean it with?
barrym381
Forum addict
Reply #7 on:
02 October 2013, 13:08 »
Quote from: Rhyso on 02 October 2013, 10:05
will prob need a new 1 with the mileage the car has done
Scottymk4
Here all the time
Reply #8 on:
02 October 2013, 13:29 »
maybe but is this an easy fix?
Golf mk4
Wazzzer
