Author Topic: Low Tyre Pressure Warning  (Read 15609 times)
Offline JellyB
Re: Low Tyre Pressure Warning
« Reply #10 on: 01 October 2013, 23:44 »
On the abs/tyre systems I've used the under inflated tyre(s) rotate faster. We used the same system to spot 4wd turn in lockup and trailer over loading, so its quite a useful thing really!
Offline mcmaddy
« Reply #11 on: 02 October 2013, 08:38 »
I must admit I thought from reading the brochure back in April that the gtd and gti came with the proper tyre pressure system and not the crappy abs one. the abs one is ok but it's cheap and not what I was expecting on delivery.
Offline monkeyhanger
« Reply #12 on: 02 October 2013, 15:10 »
Those proper sensor ones are usually ruined by the tyre changing monkeys on your first or second tyre change - just ask anyone with a "high end" Renault Laguna.
Offline mcmaddy
« Reply #13 on: 03 October 2013, 07:07 »
the sensors need replaced anyway after a few years so it would require a bit of work I would think.
Offline rocknob
« Reply #14 on: 03 October 2013, 12:33 »
Just interest sake the easiest way to tell if it is direct or indirect is to look at the tyre valves. The indirect system has normal rubber valves and the direct system has aluminum valves.
Current Car :  Tornado Red VW Golf GTI DSG DCC ParkAssist Xenons
Offline Geomets
« Reply #15 on: 03 October 2013, 17:46 »
Except if your car is a Peugeot... My current (just ordered  GTI) has plastic caps and the valve itself is made from hard plastic which tends to break!!! Had two cracked and changed them for normal ones and all of a sudden I had a car with TPMS and no sensors at all :angry:
Offline matchboy
« Reply #16 on: 04 February 2014, 13:55 »
Just to revisit this thread for information purposes, I had the tyre pressure warning come on this weekend.  I've probably done around 5k miles I think (car is 4 months old now).
Anyway, checked all the tyres and they're all on 38; fuel cap says 41 but that doesn't sound right to me as the chances of all 4 tyres losing the same pressure at the same time is highly unlikely.
Reset the system via the 'Car' setting and now all is hunky dorey.  Hopefully  :laugh:
Audi RS5 2018
Gone: BMW M4 LCI Competition Package
Previous: Mk 3 Audi TTS, Porsche 981 Cayman S, Mk 7 Golf R, Mk 7 GTI, Mk 6 GTI, Mk 5 GTI and so on....
Offline mullermn
« Reply #17 on: 04 February 2014, 15:52 »
I had the pressure light come on at about the 3000 mile mark, which was 50 miles or so after swapping the wheels and tyres for winters.
This was about a 10 days ago - I reset it and it hasn't come back since.
