Author Topic: Clutch pedal stuck to the ground?  (Read 2558 times)
Offline ProjectSnow
« on: 28 September 2013, 15:30 »
So I'm new to this forum so I'm not sure if I'm posting in the right place, but I hope someone could shine some light on a fellow Golf owner;
I was driving home happily oblivious to what was going to happen, anyway, pulled upto a set of lights and my clutch pedal literally stuck to the ground, and I couldn't change gear the Only way I got home was to power shift
Please help
Offline gazareth
Re: Clutch pedal stuck to the ground?
« Reply #1 on: 28 September 2013, 15:35 »
you will have to tell us what car you have? :whistle:
Offline AaronMc
  • GTI Life..
« Reply #2 on: 28 September 2013, 16:00 »
If its a MK4, probably the clutch pedal has snapped. Common on MK4's and happened to me when I had mine too..
Bit of a nightmare to fit a new one as youve got little bits in and little space!
Golf GTI MK6 Manual - Tornado Red with Jacara Cloth, Monza Shadows, RNS510, Dynaudio System, Fiscon Bluetooth, Front & Rear Park Sensors, ACC, Cruise Control, Winter Pack & Xenon Lights.
Offline DCmk3
« Reply #3 on: 28 September 2013, 16:02 »
If it's a MK3 I would put my money on saying the pressure-plate has been pierced by the rod that presses against that, I have had that happen to me and then the clutch was stuck to the floor as you mentioned.
or possibly the clutch cable jammed..  :whistle:
2014 Mk7 GTI - Littco L500
Offline ProjectSnow
« Reply #4 on: 28 September 2013, 16:22 »
Sorry, it's a mk4 1.8 (180bhp) model and I've been reading about the cylinder sharing with the brakes if that helps?
I check under the hood too and I can see some sort of fluid on top of the clutch housing? Near where the actually clutch operation is
Offline dom
  • Back in a Mk4
« Reply #5 on: 29 September 2013, 11:20 »
My money would be on this ^^^
Offline harlemex
« Reply #6 on: 29 September 2013, 17:33 »
slave cylinder seals have gone.
Offline brewey
« Reply #7 on: 29 September 2013, 18:01 »
Are there little pieces if plastic in the footwell? If so as Dom and others said above snapped clutch pedal. They have a little square tack welded for safety in a crash. But that means with age it weakens and eventually snaps.
It's fairly easy to change but a fiddly bugger, you need someone with small hands to help you
2000 1.8T ARZ - OEM+
Offline gm8
« Reply #8 on: 29 September 2013, 18:38 »
http://uk-mkvs.net/forums/t/18012.aspx
been there done that unfortunately . Cheap and DIYable , just a c&*t of a job
Offline paulhgti
  • GOLF 1.8T AUM 209bhp 228LB FT TORQUE
« Reply #9 on: 29 September 2013, 19:35 »
I had that happen to me in rush hour i was stuck on a roundabout for an hour totaly peed off.cheap to fix think i paid about £40 for all the parts.i took the clutch pedal out and changed it on the bench at work.couple of clips and 13mm bolts took it all out
AUM 209 BHP R-TECH STAGE 1 RE MAP,MILTEK CAT BACK 4MOTION EXHAUST,4MOTION VALANCES,PIPERCROSS FILTER,TINTS,WIND DEFLECTORS,BOOST LEAK,SANTA MONICA ALLOYS,35mm H&R LOWERING SPRINGS
