Author Topic: Random cut out??  (Read 3562 times)
Offline sbushby
Random cut out??
« on: 27 September 2013, 20:52 »
Hey all,
Strange one today. While driving along the car just died...pulled over and turned it over which it did fine. Didnt take straight away but when it did it popped and banged a bit before revving to 4k and slowly dropping.....then drove fine??
Started it later and again it was lumpy spluttering a bit before clearing then running fine??
Anyone had similair issues?
VW BUSH
Re: Random cut out??
« Reply #1 on: 28 September 2013, 11:51 »
my guess is the Coil
Offline Luke1981
« Reply #2 on: 28 September 2013, 16:05 »
Could it be a faulty MAF sensor?
MK IV GT TDI 150 PD / MKII CADDY SDI
Offline sbushby
« Reply #3 on: 30 September 2013, 08:54 »
Thanks guys.
Coil has been suggested and throttle body to. Ill clean the maf and see what happens. Thanks again
Offline Len
« Reply #4 on: 30 September 2013, 12:53 »
Unless you have been driving in very heavy rain and some electrical part got wet I would say the coil too!
www.sas.org.uk
www.the-ace.org.uk
Offline sbushby
« Reply #5 on: 27 October 2013, 23:44 »
Replaced coil, dizzy and rota arm.....also plugs and leads.....still happening?? Cam position sensor next but beginning to get annoying
Offline Deano2711
  • 1992 VR6
« Reply #6 on: 27 October 2013, 23:54 »
Sounds like the MAF to me as mine had a similar problem. Try unplugging the MAF then driving car. If it gets any worse its ok and if no different thats the problem Mate
Offline andy_k
« Reply #7 on: 28 October 2013, 00:35 »
Mine won't even start with the MAF disconnected.
If it's constant then possibly a blocked injector?
If it happens regularly when the engine gets hot then a sensor has to be the main suspect.
Offline bigberty101
« Reply #8 on: 28 October 2013, 07:31 »
Valves don't have a maf. They have a map sensor in the ecu instead. Try the blue temp sensor, causes issues exactally the same on yours, just on the right of the head near the coolant flange
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 28 October 2013, 11:06 »
looking at your other post i would take a chance of either ecu or fuel pump relay, when the car is warm touch both and see if either are red hot, Both are known to fail and can cause some odd running issues but more so after several miles of running
replace as needed
