Author Topic: Random cut out??  (Read 3570 times)
Offline sbushby
Re: Random cut out??
« Reply #10 on: 07 November 2013, 21:35 »
boneybradley., cheers for the shout. have replaced both relays and still happening........
bigberty101, at the risk of sounding mega dumb, please can you explain where this is. I have laready replaced the engine coolant temp sensor that screws into block??Is this one diffrent.
Definately only doing after its properly warm, then left for a little while.....
Update of changes so far, plugs, leads, rotor arm, dizzy, engine water temp, both fuel and ecu relays, cam position sensor,ignition coil, vacuum hoses aswell as cleaning throttle body
« Last Edit: 07 November 2013, 21:45 by sbushby »
Offline sbushby
« Reply #11 on: 09 November 2013, 23:11 »
Right guys so an update..........
Changed the "blue" sensor in water system which is to do with a thermo cut out, no joy.... ;-(
Car still playing up when warm.....so going to destroy the bloody thing..
Offline N900 MJT
« Reply #12 on: 09 November 2013, 23:32 »
Used to have this issue in very wet weather, have you changed the coil/ht leads/spark plugs yet?
Have you had it plugged into vagcom yet to see if any error codes are there?
Offline sbushby
« Reply #13 on: 14 November 2013, 23:34 »
Not plugged in yet as initial test didnt show any fault code from garage, but do think they were full of poo....
Strangely no engine lights on??
