Author Topic: Anyone running 15mm rear spacers?  (Read 2980 times)
Offline dom
  • Back in a Mk4
« on: 26 September 2013, 07:20 »
As per title, I'm looking to change my rear 20mm spacers for 15mm. I'm already running 15mm on the front and tried them on the rear but they don't sit flush with the hub, I had the same issue on my mk3.
Anyone got a link to, or brand of any 15mm spacers that fit on the rear?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Anyone running 15mm rear spacers?
« Reply #1 on: 26 September 2013, 07:28 »
I think the issue is down to if its running non genuine rear discs as i also discovered on my mk3 after trying a couple of sets of 15mm's before just chucking the 20mm's back on.
Offline km
« Reply #2 on: 26 September 2013, 07:43 »
Hi, I'm not quite understanding this? Don't sit flush on hub?
As I'm running 15mm spacers on rear?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 26 September 2013, 14:59 »
I'm running 15mm FK rear spacers which are bolt on versions. I had to get the standard wheel bolts machined down so they didn't bottom out on the hub when tightening them
Offline cullygti
« Reply #4 on: 28 September 2013, 14:57 »
I'm using 15mm on the rear and if you take the cover cap off the hub (one in the centre)  the spacer will then sit flush  :smiley:
« Reply #5 on: 28 September 2013, 21:12 »
And also allow the ingress of dirt and water into the wheel bearing.  :whistle:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #6 on: 28 September 2013, 22:23 »
 :grin: Its a valid point tho all the same
2000 Mkiv GTi 1.8T AGU
jockgti
« Reply #7 on: 30 September 2013, 18:50 »
i've got 15mm on rear from creation motorsports,they have the right size spigot so they sit flush
http://www.creationsmotorsport.com/product-detail.php?pid=140
Offline dom
  • Back in a Mk4
« Reply #8 on: 30 September 2013, 19:45 »
Perfect :afro:
Offline km
« Reply #9 on: 30 September 2013, 19:59 »
am i missing something here? spacers that fit the front but not rear?
I previously ran 15mm spacers on the front with no problems.
but swapped them for 20mm and used the 15mm for the rear when i put new set of wheels on.
And now i've got steering wheel wobble.
