Author Topic: silicone hoses  (Read 2586 times)
Offline eddypeck
silicone hoses
« on: 25 September 2013, 09:11 »
Can someone please explain the benefits of silicone hoses if there are any other than just looking pretty.
Offline dragonfly
Re: silicone hoses
« Reply #1 on: 25 September 2013, 16:45 »
Due to their contruction they will last longer than standard hoses and withstand a lot more pressure before rupturing.
Offline notenoughtime
Re: silicone hoses
« Reply #2 on: 26 September 2013, 19:07 »
They are 3-4 ply usually and don't expand with boost or collapse with vacuum like standard ones can
Offline eddypeck
Re: silicone hoses
« Reply #3 on: 26 September 2013, 23:03 »
worth the extra money on a standard road car? or over kill
Offline dragonfly
Re: silicone hoses
« Reply #4 on: 27 September 2013, 16:43 »
Personally I would leave them on a standard car. Stock items are more than up to the job.
Offline th3_f15t
Re: silicone hoses
« Reply #5 on: 30 September 2013, 15:16 »
So if you were to run an increase in power (say, 25% over stock) then swapping to silicon would be a good move?
Moving over to Flickr, sorry for the broken picture links!
Offline matt@onlychargeddubs
Re: silicone hoses
« Reply #6 on: 30 September 2013, 16:55 »
Yes it would, it's why our cooler kits come with silicone pipes, they take pressure much better so an increase in boost is certainly a time to change.
Most factory boost pipes split with age and then standard levels of boost alone.
Coolant pipe silicones are mainly for looks, coolant pipes don't often fail unless they're rubbing
Offline eddypeck
Re: silicone hoses
« Reply #7 on: 30 September 2013, 21:57 »
thanks, all I've got to do now is find a set of standard rubber hoses for my early K-Jet EV engine then, so far only found for PB digi engine. Anyone know what's different?
