Author Topic: Car cutting out on a slow left turn?  (Read 2187 times)
Offline GTi_James
« on: 21 September 2013, 19:25 »
As above guys, the motor drives fine but then when I pull into a parking bay for example it cuts out? What could this be?
Offline brewey
Re: Car cutting out on a slow left turn?
« Reply #1 on: 22 September 2013, 00:04 »
Are you low on fuel? Causing fuel starvation briefly maybe?
2000 1.8T ARZ - OEM+
Offline GTi_James
« Reply #2 on: 22 September 2013, 12:24 »
full tank as of friday bud
Offline mcgee9t2
« Reply #3 on: 22 September 2013, 12:35 »
couldnt imageine so, if it was fast cornering maybe yeah...
does it do it when your not in gear and doing a slow left turn? what about if you turn right?
Offline GTi_James
« Reply #4 on: 22 September 2013, 12:36 »
nope still in gear (2nd) and will just cut out on left turn only  :undecided:
Offline Nino
« Reply #5 on: 22 September 2013, 12:36 »
You had it scanned yet james?
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline GTi_James
« Reply #6 on: 22 September 2013, 12:39 »
yeh they said batts at 50% and no issues with the alternator as it was replaced just before i bought the motor
Offline Nino
« Reply #7 on: 22 September 2013, 12:45 »
hmmmmmm James, just a quick thought, put your stock DV on, and see if it still does it.
Offline GTi_James
« Reply #8 on: 22 September 2013, 15:26 »
no change  :sad:
im gonna get all the pipes put on and see where that gets me, they needed doing last xmas when i got the if im honest  :lipsrsealed:
Offline Chris#101
« Reply #9 on: 22 September 2013, 15:33 »
Pas on its way out, Causing to much load on the engine when idling so stalls the engine ?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
