Author Topic: Car cutting out on a slow left turn?  (Read 2188 times)
Offline GTi_James
Re: Car cutting out on a slow left turn?
« Reply #10 on: 22 September 2013, 17:44 »
Pas on its way out, Causing to much load on the engine when idling so stalls the engine ?
Pas?
Offline Chris#101
« Reply #11 on: 22 September 2013, 17:51 »
Pas?
Power assisted steering  :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline GTi_James
« Reply #12 on: 22 September 2013, 18:39 »
Oh yeh...oh crap, it feels a bit wobbly at 80mph and on acceleration so that could an option then?
Offline gazareth
« Reply #13 on: 22 September 2013, 21:49 »
check your engine bay closely for dodgy wires that could be moving and shorting out on something.
Offline GTi_James
« Reply #14 on: 24 September 2013, 17:16 »
well checked everything as well as chris's advice last night on power steering fluid, noticed the Maf plug was loose and pushed it back in, pulled a bit of black wire out of the alternator which was wierd and checked for all other loose wires, now i got a lumpy idle on an irregular basis, had the coilpack recall etc, looking to get the TIP fitted this weekend and up date as i go i suppose
