Author Topic: crank seal needs doing  (Read 4235 times)
Offline vwwvgolf
« on: 18 September 2013, 21:01 »
so, my abf needs the timing end crank seal changing. losing alot of oil and im getting scared im guna forget to top it up and its guna go bang.
would do it my self but havent got the space or the time at the moment. has anyone paid a garage to do this recently? what sort of price will i have to be paying?
or should i just put up with it and put money towards 1.8t :laugh:
Offline tweed
Re: crank seal needs doing
« Reply #1 on: 18 September 2013, 21:39 »
Might be cheaper to buy a engine
VW BUSH
« Reply #2 on: 18 September 2013, 21:44 »
No point putting old belt and tensioner on unless its new, so that's about £60.
Oil seal is about £10.
Maybe 2hrs work in a decent garage providing nothing else goes wrong should be under £200.....
Offline vwwvgolf
« Reply #3 on: 19 September 2013, 18:13 »
called the local vw specialist and said it would be around the 250 with new belts. i was expecting it to be more tbh.
and i have got a lightened flywheel still to fit once the oil is sorted, so there still some more fun to be had from it lol.
think i will stick with it!
Offline Bellend
« Reply #4 on: 19 September 2013, 19:03 »
Anyone know if they're woodruff key?
250 sounds good if they're using a decent belt kit and might as well have the water pump while it's there.
I'd do yourself a favour and get them to replace the 4 allen key bolts holding the main pulley to the crank gear. I always do it now, any VW that I do a belt on I automatically order those four bolts.
Where all my moneys went.
Offline tweed
« Reply #5 on: 19 September 2013, 20:23 »
My bad its 100% cheaper than what I thought it would cost you.
VW BUSH
« Reply #6 on: 19 September 2013, 21:52 »
Do this
Offline vwwvgolf
« Reply #7 on: 20 September 2013, 16:54 »
might be stupid question but why change the bolts??
and tweed, yeh i was expecting it to be around the 500 mark, so quite a relief really
Offline Bellend
« Reply #8 on: 20 September 2013, 19:40 »
They just strip easy once they've been in and out a couple of times. Think they're 93p each or something and theres four.
VW BUSH
« Reply #9 on: 20 September 2013, 22:47 »
Pray the thread's in the gear dont strip or its a ball ache.
