Author Topic: Gti turbo ARZ engine, how to do n249 bypass, is it a safe mod?  (Read 2998 times)
Offline Jeffvwgolf
Thinking bout doing the n249 bypass, I haven't enough knowledge on how it's done as I've been reserching for ages now. Can any1 give me a detailed intrustion on how to do it, my car is 2000, engine code ARZ and is it a safe mod to do..
« Last Edit: 08 September 2013, 22:05 by Jeffvwgolf »
Offline dom
  • Back in a Mk4
Re: Gti turbo ARZ engine, how to do n249 bypass, is it a safe mod?
« Reply #1 on: 08 September 2013, 22:14 »
This is the guide I followed:
http://uk-mkvs.net/forums/t/265883.aspx
Offline rio_gti
« Reply #2 on: 09 September 2013, 11:30 »
I followed that same guide and its pretty straight forward and worth doing... but then I ended up doing the ultimate delete to get rid of even more junk and its fine!!! (I got an ARZ too!!)
Offline Jeffvwgolf
« Reply #3 on: 09 September 2013, 12:20 »
Thanks lad, il give it ago see wat it's like then, hopefully get a remap after to :)
Offline Dalo Harkin
« Reply #4 on: 10 September 2013, 14:48 »
I also did the deletes, no issues whatsoever, I actually think it made the car feel better, maybe a placebo as you're more than likely just removing old broken crap anyway  :laugh:
Offline WadGTI
  • Golf GTI'er
« Reply #5 on: 11 September 2013, 09:21 »
I have mixed views since I did the N249 bypass. Yeah, in gerneral, the car the feels better and a bit more responsive, specially in second gear. However, when giving it a roast from 3rd to 5th, the turbo sometimes likes to stall then pick up again.
Thinking I might be need a new DV, even though the standard one sounds and looks good this now.
Offline Jeffvwgolf
« Reply #6 on: 17 September 2013, 01:58 »
I done the bypass and so far I haven't had any regrets, I can hear the turbo whistle more and it also boosts abut more with less lag and smooth threw the revs
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 17 September 2013, 07:48 »
Does the agu have this? Also what else can you delete from the agu apart from the carbon canister?
*****MK3 Anniversary*****
*****MK4 GTI T*****
