Author Topic: New Golf owner - Multiple questions  (Read 2023 times)
Offline danny133
« on: 08 September 2013, 20:31 »
Hi Guys,
New owner here!
Just traded my Audi A4 Avant for a 2001 Golf 2.0 GTI.
Few questions ..
My audi had an anti hijack feature - doors lock after 10mph .. how do i turn this on?
My audi had an audible beep on lock, it was activated via vagcom and some software (Rosstech i think) - Can i turn this on the golf?
My audi windows would roll up once i locked the car and held the lock key .. can the golf do this? even if i have to turn it on?
My electric mirrors appear not to be working, is this common or an easy fix? - twisting the knob does nothing :(
Glovebox light isnt working! Im assuming there all plugged in by default and i just need to change a bulb, any idea on size?
Thank you very much in advance :)
oh any anybody local to Suffolk, beer tokens for anybody who can do it!
« Last Edit: 08 September 2013, 20:40 by danny133 »
Offline dom
  • Back in a Mk4
Re: New Golf owner - Multiple questions
« Reply #1 on: 08 September 2013, 20:40 »
Hello,
Anti-hijack and alarm chirps can be enabled using vagcom, auto windows cannot be enabled though.
Have you checked the fuse for the mirrors? I think it's #14.
Glovebox light is a 36mm festoon bulb.
Offline danny133
« Reply #2 on: 08 September 2013, 20:56 »
Winner!
Just need a vagcom!
windows .. i guess i need one of these KVW100 things?
Good call with fuse! - No i dont know where fuse box is lol
Thanks for size! - i have a few (i think!)
Offline bonny
« Reply #3 on: 08 September 2013, 21:54 »
I beg to differ, i had this done on my gt tdi 130  :whistle:
The more you pay The faster you go.....
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« Reply #4 on: 08 September 2013, 21:58 »
Winner!
Just need a vagcom!
Main fuse box, open the drivers door. On a panel covered by a little plastic door on the side of the dashboard.
I thought Volkswagens were supposed to be reliable?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 08 September 2013, 22:01 »
auto windows can only be enabled on immo3 equipped cars and you need another program, not VCDS or VAG TACHO
Offline dom
  • Back in a Mk4
« Reply #6 on: 08 September 2013, 22:03 »
That's interesting, don't suppose you know what the software is? Mine is immo3 and its one thing I miss about my mk3
Offline Scott D
« Reply #7 on: 08 September 2013, 22:04 »
VDS Pro is needed for auto windows
There is some free software that can be used with ebay leads that works on some later modules cant remember the name but searching on here should find the thread
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline danny133
« Reply #8 on: 08 September 2013, 22:06 »
Offline Scott D
« Reply #9 on: 08 September 2013, 22:11 »
thats the one, worked spot on with my 2003 car
