Golf mk4
Wazzzer
Strange wheel/engine noise
Topic: Strange wheel/engine noise (Read 2798 times)
MK4_Golf_20VT
Just got here
08 September 2013, 10:27 »
Noticed a knocking from passenger side wheel area so jacked it up today to see if i could see anything obvious or loose etc.
Turned the wheel which had some play in it, don't know if this is normal or not ? anyway when i span the wheel this awful sound happens so i uploaded this video for someone to hopefully enlighten me on this if possible.
http://youtu.be/n9Hfz-Q1VCI
I dont know what this is and it sounds unhealthy anyway!
Nino
Re: Strange wheel/engine noise
08 September 2013, 10:52 »
Sounds like a wheel bearing is gone to me
Like my badge? Get one here:
https://www.golfgtiforum.co.uk/index.php?topic=291134.0
VW Car history
- Mk3 1.8 GL - Silver - 5 door, Mk4 1.8t - Silver - 3 door, Mk4 R32 - Black - 5 door, Mk5 GTi - Black - 5 door, Mk4 R32 - Deep Pearl Blue - 3 door, MK6 2.0 TDI - Graphite Blue - 5 door, MK7 GTD - Solid Black - 5 door.
Current
- MK6 GTi Edition 35 - Candy White - 3 door
MK4_Golf_20VT
Just got here
08 September 2013, 11:19 »
Thats what i thought hearing the first clunking on there but theres no play in the wheel when i try twist it just when i rock it back and forth. And the loud noise after that sounds like its coming from nearer the engine
Nino
08 September 2013, 12:56 »
A worn wheel bearing will give play when you rock the wheel
VW Car history
Current
MK4_Golf_20VT
Just got here
08 September 2013, 13:43 »
ah i see, since youve listened to the vid any idea what the loud grinding noise is when i spin the wheel ?
Nino
08 September 2013, 14:51 »
Hard to say really, prob just the wheel baring but could be the drive shaft?
VW Car history
Current
MK4_Golf_20VT
Just got here
Reply #6 on:
08 September 2013, 16:55 »
Thats what i thought it could be but never heard that sound before so i couldnt tell, is it an expensive job to do a driveshaft
MoshiMoshi
GTI forum regular
Scorpion Exhausts are delightful.
Reply #7 on:
09 September 2013, 16:08 »
Thats what mine did when it needed a new wheel bearing. Try that first, it doesn't cost much, If I recall it was about £70 for it, labour included.
I thought Volkswagens were supposed to be reliable?
MK4_Golf_20VT
Just got here
Reply #8 on:
09 September 2013, 20:54 »
Ok i will thanks , still safe to drive is it ? Gotta go from grimsby to bournemouth at the weekend and its a long drive!!
MoshiMoshi
GTI forum regular
Reply #9 on:
09 September 2013, 21:02 »
I wouldn't advise it, any play in the bearing puts unwanted, extra strain on the entire bearing/hub. I wouldn't want to drive far. You could get a part ordered and have it sorted in 2 days. I'd advise fixing it before the drive. A wheel coming off will cost you a lot more than the bearing
Golf mk4
Wazzzer
