Author Topic: Strange wheel/engine noise  (Read 2792 times)
Offline dom
  • Back in a Mk4
Re: Strange wheel/engine noise
« Reply #10 on: 09 September 2013, 21:51 »
I wouldn't advise it, any play in the bearing puts unwanted, extra strain on the entire bearing/hub. I wouldn't want to drive far. You could get a part ordered and have it sorted in 2 days. I'd advise fixing it before the drive. A wheel coming off will cost you a lot more than the bearing  :grin:
^^^ This, get it sorted before making a journey like that!
Offline mike1990
« Reply #11 on: 09 September 2013, 21:55 »
and I've made a journey like that. Was only going 10mph in my old polo a few years ago.. wheel bearing gave way and the wheel just continued making a big escape from me. Luckily, me and other road users was fine. Get it fixed soon as possible
Offline chubbz1005
« Reply #12 on: 09 September 2013, 23:30 »
the last time mine went u couldnt feel much play in the wheel but it did sound like grinding brakes when goin round bends
Offline gazareth
« Reply #13 on: 11 September 2013, 00:09 »
that sounds more like a bad diff to me. have you checked the gearbox oil? could be the bearing but tbh Iv never heard one making that kinda noise before. use a long screwdriver with your ear to the end of it to pin point the noise.
Offline MK4_Golf_20VT
« Reply #14 on: 11 September 2013, 01:31 »
I was kinda swaying to it being the diff as it sounds more behind the wheel rather than in it, but ill get a bearing done on the safe side then see if it still does it.
Had a dual mass flywheel kit put in 2 year ago would they of done the gearbox oil then ?
« Reply #15 on: 11 September 2013, 10:55 »
Whatever happens I would not drive that any distance.
Offline gazareth
« Reply #16 on: 11 September 2013, 18:30 »
no need to drain the oil in them boxes when you pull them out since the shafts bolt to the flanges on the outside. but I would check it for oil anyway. if your really keen you could take off the driveshaft and spin the wheel to check for noise. if it gone then your box is suspect. wouldn't change wheel bearing until noise source confirmed.
« Reply #17 on: 12 September 2013, 09:08 »
Yeh im leaving the bearing till i know what the grinding noise is because ive heard wheel bearings before and im not convinced its that, itll be in the garage next week so ill know more then hopefully.
