Author Topic: Knocking noise  (Read 1097 times)
Offline ShauniiBoii
Knocking noise
« on: 05 September 2013, 16:14 »
Aryt boys, have a knocking noise on my car only sounds on full lock and on bumps / potholes it comes from front right? what do you guys reckon it is?
On bumps it rattles and sounds like something is loose
on full lock it groans / knocks
Driveshaft only thing I can think of really :\
Offline dom
  • Back in a Mk4
Re: Knocking noise
« Reply #1 on: 05 September 2013, 16:26 »
Could be one of many things tbh, ARB bushes are a possibility
Offline ShauniiBoii
Re: Knocking noise
« Reply #2 on: 05 September 2013, 16:35 »
would be fine if it was that as im planning on upgrading it for collies :)
Offline bonny
Re: Knocking noise
« Reply #3 on: 05 September 2013, 21:20 »
ball joint, arb bushes, drop links etc etc  :whistle:
The more you pay The faster you go.....
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: Knocking noise
« Reply #4 on: 06 September 2013, 10:48 »
jack the car up and check the front wishbone rear bushes. they are prone to splitting due to them having voids and not being solid rubber. Also other possible cause is knackered strut tops.
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: Knocking noise
« Reply #5 on: 06 September 2013, 13:50 »
Just done this on mine. Was lose ball joint and the driver side ARB bush was shot to pieces! sounded like someone shacking a tin can with a marble in it :grin:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
