Golf mk4
Wazzzer
oil..short journeys
Topic: oil..short journeys (Read 3004 times)
navmk4gti
Forum addict
oil..short journeys
04 September 2013, 23:20 »
In regards to my v6 4mo.. i av 0-40w vw oil in there since last service .. 6k miles ago.. the car sounds very tappety when starting from cold...and recently i do a lot of short journeys.. 5 mile trip then 5 mile back home.
What grade oil you guys recomend? I was gong to go for 10-40 which is what vw used before they changed it to 0-40. Im thinking get it from opi oils this time but that lists 5-30 when i select my car.. so well confused.com now lol
Bit advice be good
Website:
https://www.theonestopledshop.com/
gazareth
Re: oil..short journeys
04 September 2013, 23:25 »
what mileage on your engine?
barrym381
Forum addict
04 September 2013, 23:26 »
you sure its not chain rattle
navmk4gti
Forum addict
04 September 2013, 23:28 »
62k
Website:
navmk4gti
Forum addict
04 September 2013, 23:49 »
Nope defo not a rattle like slight tapping sound as if the oil has not got up the engine enough.. stays like that till temp starts creaping up then its uber quiet
Website:
gazareth
05 September 2013, 00:01 »
could be the hydraulic lifters starting to wear or maybe getting gummed up. also were them engines not prone to oil pick up gauze getting clogged?
Last Edit: 05 September 2013, 00:04 by gazareth
navmk4gti
Forum addict
Reply #6 on:
05 September 2013, 00:09 »
Not sure on that.. im getting it lookd at on saturday will see if they can check oil pickup pipe sumhow..
What grade oil you guys think i should go for then?
Website:
gazareth
Reply #7 on:
05 September 2013, 00:11 »
were they prone to oil pick up gauze blockage?
navmk4gti
Forum addict
Reply #8 on:
05 September 2013, 09:32 »
Quote from: gazareth on 05 September 2013, 00:11
No idea mate.. maybe someone can clarify
Website:
gazareth
Reply #9 on:
05 September 2013, 18:20 »
you should get the oil pressure checked first. if the gauze was restricted then the thick cold oil would struggle to get through it on first starts of the day. but when it warms and thins it would flow through the gauze easier.
Golf mk4
Wazzzer
oil..short journeys
