Author Topic: oil..short journeys  (Read 3006 times)
Offline james2
  • No scammers please.
Re: oil..short journeys
« Reply #10 on: 05 September 2013, 20:21 »
you should get the oil pressure checked first. if the gauze was restricted then the thick cold oil would struggle to get through it on first starts of the day. but when it warms and thins it would flow through the gauze easier.
But 0w 40 is the best oil from cold start it does not have to warm up to thin out.
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
« Reply #11 on: 05 September 2013, 20:24 »
In regards to my v6 4mo.. i av 0-40w vw oil in there since last service .. 6k miles ago.. the car sounds very tappety when starting from cold...and recently i do a lot of short journeys.. 5 mile trip then 5 mile back home.
What grade oil you guys recomend? I was gong to go for 10-40 which is what vw used before they changed it to 0-40. Im thinking get it from opi oils this time but that lists 5-30 when i select my car.. so well confused.com now lol
Bit advice be good :wink:
You mean 0w 40 not 0 40w  :evil:
Offline gazareth
« Reply #12 on: 05 September 2013, 21:40 »
but all oils thin out when they warm up. just like ice cream :grin:
Offline navmk4gti
« Reply #13 on: 06 September 2013, 00:16 »
I will get the lads at midlands vw to have a look at it to see if it is blocked. Is there any diy way to check oil pressure?
Offline barrym381
« Reply #14 on: 06 September 2013, 00:21 »
pretty sure they can check with vag com if the chain is stretched but its usually the tensioner that goes 1st just in case its that   :undecided:
Offline navmk4gti
« Reply #15 on: 06 September 2013, 00:32 »
Would it not make the noise all the time and drive like sh1t if the chain is stretched tho :undecided:
Offline gazareth
« Reply #16 on: 06 September 2013, 00:58 »
only if you have a gauge can you check the oil pressure. to check for gauze blockage the sump would need to come off. so I would get pressure checked first. surely the chain cant be gone at 62k?
Offline navmk4gti
« Reply #17 on: 06 September 2013, 01:08 »
Ah k will look into getting oil presure gauge fitte did want a gauge in the car anyway :grin:
Im going to go for 5-40 mobil oil which is 502 vw approved.  Will have to wait till then to see if anything is blocked if the sump needs to come off
Offline paultownsend
« Reply #18 on: 06 September 2013, 17:03 »
Do you have a pair of stands and a jack?
If so do it yourself.
Use Synta platinum oil and fit a new pick up pipe/gauze. On these engines it's a must.
I Believe these engines suffer from sludge build up because the wrong oil is used at wrong intervals.
Use proper VW oil and change it every 5k.
I wish I'd have picked up a V5 or even better a V64mo instead of the 1.8t. Great engine you have there, and drivetrain.
« Last Edit: 06 September 2013, 17:06 by paultownsend »
Offline navmk4gti
« Reply #19 on: 06 September 2013, 18:06 »
I do have stands and a jack but no driveway  :embarrassed:
Any idea how much these pick up pips go for? I will get it replaced on the next week when get service done :smiley:
