Author Topic: turbo change on a 1.8t auq  (Read 1743 times)
Offline darren1.8t
  • I HATE FRENCH CARS
« on: 03 September 2013, 21:27 »
hi guys has anyone changed a turbo on a 1,8t how hard is it? can it be done with manifold on ?
Offline Ben@VWH
Re: turbo change on a 1.8t auq
« Reply #1 on: 04 September 2013, 09:13 »
Hi, it's a pretty straight forward job to change the turbo. There are 2 main ways of approaching it, either work from the top, removing the manifold, disconnecting the lines, disconnecting the downpipe and lifting out the top. The second popular approach is to remove the o/s driveshaft, remove lines/downpipe/tip and drop the turbo out the bottom of the car.
Offline darren1.8t
« Reply #2 on: 04 September 2013, 14:01 »
Hi cheers mate but can it be done with keeping manifold on?
Offline darren1.8t
« Reply #3 on: 05 September 2013, 17:22 »
Anyone ??
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« Reply #4 on: 05 September 2013, 17:37 »
I sincerely doubt it could be done keeping the manifold on. It needs to unbolt from the manifold, and be pulled upwards. The exhaust manifold would simply be in the way.
I thought Volkswagens were supposed to be reliable?
Offline Ben@VWH
« Reply #5 on: 13 September 2013, 17:01 »
Yes, can absolutely be done with the manifold on, but it is a lot simpler to undo the 13 manifold nuts and make the job easy for yourself by removing it. :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 13 September 2013, 20:10 »
do it from the top and remove the manifold unless you have a ramp to use. I've done it both ways I wouldn't say one method is any easier than the other
