Golf mk2
Rear wheel bearing
Topic: Rear wheel bearing (Read 2037 times)
devilscaff
Here all the time
allways up for alaugh
Rear wheel bearing
02 September 2013, 15:19 »
Rear wheel bearing re-placement, is it a job for an armature on the drive or does it have to be a pro. Just wondering as mot comming up soon and last time it was an advisory and wanting to keep cost down ta
notenoughtime
GTI forum regular
Re: Rear wheel bearing
02 September 2013, 15:26 »
Easy Job tbh
oakgreener
GTI forum regular
02 September 2013, 18:48 »
Yeah, straight forward job. Just make sure you don't do the nut up too tight or you'll be doing it again in about a month
devilscaff
Here all the time
02 September 2013, 22:28 »
How tight is to tight?
Sgt_Lemon
8v owners club
02 September 2013, 23:02 »
I need to do this, is there a torque setting for it?
gazareth
02 September 2013, 23:50 »
what I do is nip them up with ratchet. then back them off a little bit at a time until I can just feel play in them and no more. its a lot safer having them slightly loose than to tight. but however much you adjust them up they allways seem to go loose again pretty quick. its like they have a default setting lol.
notenoughtime
GTI forum regular
Reply #6 on:
03 September 2013, 08:09 »
As above but don't leave the play, spin the wheel and it should spin freely.
oakgreener
GTI forum regular
Reply #7 on:
03 September 2013, 09:18 »
I have a box spanner that I do them up tight, with a tommy bar, (screw driver). I then back it off and then re-tighten by hand by gripping the box spanner.
Sgt_Lemon
8v owners club
Reply #8 on:
03 September 2013, 09:47 »
Wow really loose then to what I thought. Natural instinct says to make everything FT
Golf mk2
Rear wheel bearing
