Author Topic: Cone Filter Questions  (Read 2983 times)
Offline MoshiMoshi
  • Scorpion Exhausts are delightful.
« on: 30 August 2013, 00:22 »
Looking to get a cone filter, probably an s2000 filter. But I have 2 questions.
1) What silicon reducer will I require for my standard MAF, and where do I buy it?
2) What do I use to filter my secondary air pump. As the hose connects to the airbox, with no airbox, I will have no filter. I don't want to delete the SAI.
Thanks again!
I thought Volkswagens were supposed to be reliable?
Offline Nino
Re: Cone Filter Questions
« Reply #1 on: 30 August 2013, 07:30 »
You don't need to out a filter on the sai pipe but I did more for engine dress up purposes the MAF end will need 70-72mm and the filter end is 86mm I think
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline MoshiMoshi
« Reply #2 on: 30 August 2013, 10:18 »
Why is it that you don't need to filter the SAI pipe? Probably asking dumb questions here.
Offline Nino
« Reply #3 on: 30 August 2013, 12:20 »
it only turns on for the first 90sec of the engine being started, its not that you "don't need one" more that it wont hurt if you do not use one.
Offline MoshiMoshi
« Reply #4 on: 30 August 2013, 12:36 »
Cool, well I've ordered an s2000 filter and a reducer. Where did you get your SAI filter? I like the idea of having one, and where on earth should I mount the SAI hose once the airbox is gone?
Offline Nino
« Reply #5 on: 30 August 2013, 16:04 »
I cable tided the pipe to something nearby then used a universal oil breather filter from ebay
Offline westylakey
« Reply #6 on: 30 August 2013, 17:33 »
Ebay item 390603431983 is what I used for the sai
2001 AUM 1.8T, Remap, Forge 008, AGU Charge Pipe, 3" Decat to 2.5" Jetex System, S2000 Filter Inc H/S
Offline MoshiMoshi
« Reply #7 on: 30 August 2013, 19:31 »
Thanks guys! All the stuff is ordered, I'll let you know how I get on. How much different is the noise of the turbo/dump?  :evil:
Offline jay26
« Reply #8 on: 01 September 2013, 09:19 »
I took mine up the road without my air box on to test a new part before I put it all back together and it sounded awesome  :grin: without it on so if its like that then I may have to get one of these filters  :whistle:
Offline UnCl3RoRy
  • Silver - 2001 1.8T AUM
« Reply #9 on: 01 September 2013, 11:04 »
I have sub question for this, what do you do with the MAF sensor?
If you no longer go for a gap that exists, you are no longer a racing driver - Ayrton Senna
