Author Topic: Track rods  (Read 1843 times)
Offline ant_gti
  • mk3 20v turbo
Track rods
« on: 29 August 2013, 11:28 »
Hi everyone,I need to change my track rods and I believe there were 2 differnt racks used.is there any way of checking which rack is fitted.its a 1992 gti 8v.Any help would be great  :smiley:
Offline ttelracs
  • The Fettler
Re: Track rods
« Reply #1 on: 29 August 2013, 11:57 »
Hi
At my local motor factors, GSF or Euro Car Parts I give them my number plate and they should then be able to confirm the correct one.  You can then use the info to search on ebay if need be, but GSF and ECP would be my first port of call.
Offline ant_gti
  • mk3 20v turbo
Re: Track rods
« Reply #2 on: 29 August 2013, 12:28 »
Thanks for your help bud
Offline Lurky
Re: Track rods
« Reply #3 on: 29 August 2013, 14:51 »
Just had a quick look at work  there are manual steering ,trw powered steering ,zf powered steering-lhd only ,
give these part numbers to your local motor factor they shoul be able to xref
Manual steering Rack End LH & RH M14x1.5 RHT male thread FTR 4446
Powered steering Rack End LH & RH M14x1.5 RHT male thread FTR 4448
Tie rod ends if u need em same on both powered/manual
Tie Rod End - Outer LH M14x1.5 RHT female thread FTR 4239
Tie Rod End - Outer RH M14x1.5 RHT female thread FTR 4169
