Author Topic: auq engine holding back plus oil from turbo down to pancake pipe?  (Read 3767 times)
Offline darren1.8t
  • I HATE FRENCH CARS
hi guys im back!! I need help with a issue on a auq 1.8 180 on tickover it seems to be ok then it seems to hesitate then ticks over then does it again?? it also seems to feel like its holding back on full throttle? if I put my food down it holds back slightly then as I let off the throttle it picks up?? and also I have found some oil from the turbo to the intercooler on the pipe leading to the pancake pipe could it be a seal??
any help would be great guys as ive lost my touch now lol also no codes on vagcom  :cry:
Offline barrym381
unplug your maf an see how it runs  :smiley: an the oil is a sign of a boost leak check all the pipe are connected
« Last Edit: 28 August 2013, 20:51 by barrym381 »
Offline darren1.8t
cheers barry ive checked all other pipes its just the pancake pipe has oil on it !!! I have the pipe with the clip if u no what I mean does it need a seal? cheers
Offline rfn_hodgson
Hey buddy I had the oil coming from that pipe so I ended up getting the agu charge pipe that way it's not clipped in, it has a jubilee instead ;)
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline darren1.8t
Ok mate did u lose boost at all???
Offline xtetx
yes you can do pal. Change to an AGU charge pipe asap!  :smiley:
Offline darren1.8t
Just found my crankcase breath is split and held together by take.. It's the one that's a pig to get to will this cause issues?
Offline xtetx
Yep they turn to mush!
Standard issue with a golf of this age!
 Just go on eBay and search for auq and some silicone breather pipes will come up!
I also think forge have them now.
Offline Scott D
AUM/AUQ charge pipe connection is dog turd and massively prone to leaking
Get a AGU charge pipe and I strongly recommend getting a Samco turbo outlet hose with good strong clips or clamps, hose is much tigher then the OE no chance of it slipping off.
http://www.ebay.co.uk/itm/Samco-Silicone-Turbo-Outlet-Hose-Volkswagen-Golf-MK4-1-8T-/281147428732?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4175b14f7c
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline darren1.8t
cheers guys would the breather cause bad running?
