Author Topic: DIY braided fuel lines  (Read 2464 times)
Offline Nino
« on: 27 August 2013, 23:15 »
Hey guys, seeing as I am having a complete and utter nightmare finding myself stainless steel braided fuel lines for my engine, I have decided to look into making my own, I found this....
http://www.ebay.co.uk/itm/Stainless-Steel-Braided-Hose-Rubber-Over-Braid-Fuel-Line-Hose-Petrol-OverBraid-/270955419316?pt=UK_DIY_Materials_Plumbing_MJ&var=570075585064&hash=item3f163396b4
looks like it will do the job, however I am unsure of what Diameter the pipe needs to be, also Im thinking I could use the same pipe for my coolent, again im not knowing the Dia of the pipe so any help would be great :)
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Nino
Re: DIY braided fuel lines
« Reply #1 on: 28 August 2013, 09:59 »
Anyone  :huh:
« Reply #2 on: 28 August 2013, 10:52 »
With the pressures involved I would leave the fuel lines to a specialist.
Offline Nino
« Reply #3 on: 28 August 2013, 11:23 »
Okie dokie, thanks Wayne, any recommendations?
« Reply #4 on: 28 August 2013, 21:02 »
Might be worth having a word with Rhyso but a good hose supplier should be able to help.
Offline notenoughtime
« Reply #5 on: 28 August 2013, 21:05 »
Abbey hose or pirtex would be able to supply what you need, measure what you want and thread sizes on the end and they will make what you need, I used these on a 3dr cossie race car many years ago.
« Reply #6 on: 28 August 2013, 21:09 »
Not sure on Pirtek these days as HSE limits them a little as to what they can and cannot do.
Offline EsSeX dAn
« Reply #7 on: 31 August 2013, 23:50 »
how about this stuff. ebay item 330528721461 its basically what your looking for, you can get finisher end bits that finish things nicley. hope that helps!
i think i love you.....
Offline Nino
« Reply #8 on: 01 September 2013, 07:10 »
That does look good, what do others think? What finisher bits would you recommend?
