Author Topic: What should be my first engine modification?  (Read 3572 times)
Offline GTiIVTurbo
« on: 26 August 2013, 13:01 »
I have just got a MKiv Golf 1.8 turbo and would like to know what should be my first few engine mods?
Any help and advice will be much appreciated! Apart from a ss exhaust the car is totally standard!
Offline navmk4gti
Re: What should be my first engine modification?
« Reply #1 on: 26 August 2013, 17:12 »
A forge  007p or 008p recirculating valve then a remap :wink:
Offline Rhyso
« Reply #2 on: 26 August 2013, 18:53 »
Firstly I'd make everything is in tip top condition; give the engine a full service and make sure all the pipework is intact. Then go for more power
Hope you got deep pockets though  :lipsrsealed:
Offline GTiIVTurbo
« Reply #3 on: 26 August 2013, 19:12 »
Engine and all pipe work has been checked and is solid! Forge recirc was going to be my first mod, and a panel filter as I've read they are better and will get more power than an induction kit! Would get it re-mapped after that! Is a panel filter the way to go? Thanks for your Info so far!
Offline Kruga
  • Silver - MK4 1.8T AGU 2000
« Reply #4 on: 26 August 2013, 19:22 »
Start off with a forge 007p then either get a panel filter (i bought the pipercross one then gave it to a mate) and bought a cai instead was more after that dump valve "pssssh" sound than anything, then a decent exhaust maybe replace some of the pipe's with silicone one's then get a remap.. thats what i done
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 26 August 2013, 19:26 »
What about the s2k filter?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline ReDBull
« Reply #6 on: 26 August 2013, 19:27 »
The standard Bosch DV is very good so unless it needs replacing stick with it. A cone filter will flow better that the air box. As you've got a SS exhaust I'd go for a TIP. Forge TIP  are good but the SFS super size are the ones to go for. Keep away from the creation motor sport crap.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline james2
  • No scammers please.
« Reply #7 on: 26 August 2013, 19:54 »
Sounds like how i did mine but with out the exhaust. Love the cai noise. Gave my k&n panel filter away and my k&n induction kit ,they sucked.  :whistle:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline james2
« Reply #8 on: 26 August 2013, 20:07 »
lol ,your sig and still with out a map/ get it remapped.  :wink:
Offline Nino
« Reply #9 on: 26 August 2013, 20:59 »
First thing I did was get vagcom on and made a shopping list for all my errors  :whistle:
A year later and I have finally fixed my 17005!!!  :smug:
But honestly if your engine is healthy fisry mode would be a forge 007/008
Current - MK6 GTi Edition 35 - Candy White - 3 door
