Author Topic: What should be my first engine modification?  (Read 3573 times)
Offline GTiIVTurbo
Re: What should be my first engine modification?
« Reply #10 on: 26 August 2013, 21:02 »
Thanks for all the info guys! Really would love the pssshhhtttt noise but want my engine to be as healthy as it can be! What I've read so far with panel filters and induction systems has been 50, 50! I am unsure what to go for! Read a lot of people saying that induction kits are a drawback as they just suck in hot air from the engine! I will eventually get an intercooler fitted! I want it to be as cold as I can get it!
Offline ReDBull
« Reply #11 on: 26 August 2013, 21:06 »
The standard Bosch DV is very good so unless it needs replacing stick with it. A cone filter will flow better that the air box. As you've got a SS exhaust I'd go for a TIP. Forge TIP  are good but the SFS super size are the ones to go for. Keep away from the creation motor sport crap.
lol ,your sig and still with out a map/ get it remapped.  :wink:
It's booked in at R-Tech at the end of September  :wink:
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
Offline ReDBull
« Reply #12 on: 26 August 2013, 21:10 »
Cone filters flow so much better. As for sucking hot air in I'm not so sure. Static on a RR... but driving cold air moves backwards through the engine bay. Any way a big FMIC will take care of intake temps.
Offline GTiIVTurbo
« Reply #13 on: 26 August 2013, 22:02 »
Which cone filter would you recommend?
Offline Scott D
« Reply #14 on: 26 August 2013, 22:51 »
honda s2000 filter if you dont mind renewing every 12 months £12-20 they are from ECP or eBay
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline GTiIVTurbo
« Reply #15 on: 26 August 2013, 23:00 »
Why a S2000 filter?
Offline Scott D
« Reply #16 on: 26 August 2013, 23:10 »
They are cheap to buy and good gains
Sound good too if noise is what your after
Offline ReDBull
« Reply #17 on: 27 August 2013, 20:08 »
I've got a honda S2000 filter
Jetex, Green filters are good and BMC twin cone. At the end of the day it's an air filter buy which one you like the colour of.
Offline mcgee9t2
« Reply #18 on: 27 August 2013, 20:28 »
how come your inlet mani is the opposite way to mine? do lcr's have the throttle body on rhs and golfs have them on lhs?
Offline sharki786
  • GOT BOOST??
« Reply #19 on: 27 August 2013, 22:05 »
Bams and amk have it on the op side. Dont know why :undecided:
*****MK3 Anniversary*****
*****MK4 GTI T*****
