Author Topic: Mk4 golf heat shield DIY help needed  (Read 7459 times)
Offline Chris#101
« on: 23 August 2013, 21:06 »
Evening all. Want to make the most of this weekend so have got my self a sheet of aluminium to make a heat shield for my air filter.
My big ask is I know a few of you guys are running fairly similar heat shields to this
http://www.ebay.co.uk/itm/VW-Golf-mk4-A3-Air-intake-heat-shield-open-cone-shield-cupra-/141041255994?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20d6b6c63a
So would it be possible for someone to draw me a rough stencil with dimensions ?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline navmk4gti
Re: Mk4 golf heat shield DIY help needed
« Reply #1 on: 23 August 2013, 21:20 »
Ill measure mine up for you tomoz..unless someone beats me to it :grin:
Offline Chris#101
« Reply #2 on: 23 August 2013, 21:31 »
It would be much appreciated if you could bud, I've got a morning to spare on my Todd tomorrow  :lipsrsealed:
Cheers man
Offline mar_k
« Reply #3 on: 23 August 2013, 21:42 »
I would have sold you the same heat shield for £15, I recently took mine off as I think its a sh!te design,
Needs a base imo and also restricts airflow to the filter.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 23 August 2013, 23:18 »
And me please :wink:
Offline damien010685
« Reply #5 on: 24 August 2013, 00:47 »
Works fine on mine and how does it restrict air??? Your air intake is pointed right at it!!
Offline navmk4gti
« Reply #6 on: 24 August 2013, 10:22 »
+1
Cheers man
Right so measured it up.. ruffly ..hard to get a ruler around it :grin:
The hieght all around is about 8.5". The left side of the shield(side faces front the car)  is 8.5" in length.. the rear is 8" in length (side the maf hole will be) and the right side of the shield ( side faces back of the engine) is 5" in length.
Width ofcourse is whatever thickness sheet your using :wink:
Only issue is looking at it its got a slanted design its not exactly square. And the brackets are sticking out on it havent added them in the sizes :smiley:
Offline Chris#101
« Reply #7 on: 24 August 2013, 11:29 »
+1
Cheers man
legend thankyou very much will keep me entertained. Just to prove how bored I am haha..... is this correct
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 24 August 2013, 11:47 »
how far down is the hole for the MAF to fit through?
Offline mar_k
« Reply #9 on: 24 August 2013, 14:33 »
All I know is the car runs far better without the shield fitted, In my opinion the sides of the shield sits to close to
a JR/Jetex filter,
