Author Topic: strange wining noise  (Read 2081 times)
Offline t-dub1902
« on: 23 August 2013, 18:03 »
As title ots when i rev and very faint on idle any ideas what it could be??
Offline oakgreener
Re: strange wining noise
« Reply #1 on: 23 August 2013, 21:24 »
A bearing? Alternator. waterpump, power steering. Take the belts off and spin them by hand, listen for bearing rumble
Offline notenoughtime
« Reply #2 on: 24 August 2013, 20:44 »
or even start it up and use a long bar/screwdriver and place end on alt/pump etc then stick your ear on the end of bar/screwdriver and you should be able to pin point the whine
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 24 August 2013, 21:00 »
Take wife/girlfriend out of car and re-check before you do anything further.
If it's not the other half it'll probably be the alternator bearings.
Offline gazareth
« Reply #4 on: 25 August 2013, 15:09 »
could be a mouse in your airbox.
Offline t-dub1902
« Reply #5 on: 25 August 2013, 19:41 »
Haha ill try the screwdriver tommorrow its werid how its just gone though was no noise now all of a sudden it does ot ive noticed more as its warmed up!!
Offline Gambit
« Reply #6 on: 26 August 2013, 08:09 »
Has it always done it? Or just started doing it?
Screwdriver trick usually works or.....
Just remove the aux belts and start car. If it still whines then check timing belt tension and tensioner. If it stops then stick alternator belt back on start car etc until you find component causing it
