Author Topic: Green nipples on GTi (vacuum?) Hose  (Read 2534 times)
Offline andy_k
« on: 20 August 2013, 17:48 »
What do these do?
Should they be allowing air into the system or are they meant to be an airtight seal?
If I place a finger over the end of them whilst the engine is running I can feel suction.
Offline boneybradley
  • Back in a Mk3...
Re: Green nipples on GTi (vacuum?) Hose
« Reply #1 on: 20 August 2013, 18:10 »
should be air tight, when you plug them you'll notice the idle settle (or you should) and I believe only available with the pipe! (I taped mine)
Offline andy_k
« Reply #2 on: 20 August 2013, 18:16 »
thanks - will seal them but what are they supposed to do?
It's unlike a car manufacturer to put 'spare' bits on a car :)
Offline madmanmart
« Reply #3 on: 20 August 2013, 21:31 »
Take off for things like Aircon.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Offline andy_k
« Reply #4 on: 20 August 2013, 22:05 »
excellent, so I can bypass that pipe altogether then?
There's a job for tomorrow :)
Many thanks
VW BUSH
« Reply #5 on: 21 August 2013, 23:44 »
Many thanks
That's a non return valve you kind of need it, just make sure the ports are blanked off :smiley:
Offline D Squared
« Reply #6 on: 23 August 2013, 06:51 »
my green blank had melted underneath on mine, so like you thought i'd just blank it...but when i went to take of the melted green blank the whole stub tube just snapped off the one way valve, so be careful..!
i ended up using a soldering iron to melt plastic across the hole to seal it in the end, with a view to getting another one at some point....but never got around too it yet...
MK3-MK5- Now MK7 GTi
Offline Rossco250
« Reply #7 on: 24 August 2013, 09:44 »
One of my nipples was broken at the end and was making it idle rough. Just happened to stumble across it when my rubber glove got sucked into it! Lol. Blocked it with some chemical metal (all I had in the garage) and now she idles sweet :-)
Offline andy_k
« Reply #8 on: 25 August 2013, 00:59 »
thanks guys, idle is fine, just need to work out why it seems low on power around 2k revs - tried 2 different MAFs and both give the same result
