Author Topic: 8V GTI conked out again.  (Read 4462 times)
Offline GOLF-MK3-GTI
« on: 18 August 2013, 16:54 »
As above was driving at 30MPH and oil light came on and revs dropped to zero. Tried cranking it 3 times, but nothing happens. So rang me brother to bring tools as I thought it's the ignition coil. I had a spare one in boot.
After 15 mins, just tried to start it whilst I was waiting for my brother, it started. Drove home and turned it off, then started it again, it started. Switched it off, tried for the second time, it refused to start. So took coil lead off and put it to the new one that I've got in boot, it started. Switched it back to the old coil. It starts again.
So I'm thinking could it be the coil? Or does the lie somewhere else?
Ignition coil is new, it's had a new crankshaft sensor out in less than a year old.
Re: 8V GTI conked out again.
« Reply #1 on: 18 August 2013, 18:03 »
I'm going to run the engine on the new coil I have. See if it cuts out? If it does then the problem ain't the coil. It's somewhere else.
I'm not going to let this problem defeat me  :wink:
will update soon folks
Offline Screech16v
  • MK3 20vt AGU
« Reply #2 on: 18 August 2013, 18:20 »
Intermittent problems are the best  :evil:
Offline dibs1980
« Reply #3 on: 18 August 2013, 21:34 »
Could be the fuel pump relay or the power supply relay or both lol
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 18 August 2013, 22:35 »
This.
Or just keep revving the car (stationary) with new coil pack. If it cuts out then i would change the relays
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #5 on: 19 August 2013, 14:03 »
Bit of a head scratcher now tbh.
Despite knowing that the GTI has an intermittent problem of cutting out. my brother and i took it out for a spin  :grin:
Parked in traffic and the car just cut out, tried cranking it, but starter did nothing. it didnt even make a noise. so we bumped the car, it started.
Drove home and swithced it off, tried starting it back up. but the key is only turning. It feels as though the starter isn't responding.
So we get the hammer out and wack it a few times as we though its the starter thats at fault. but guess what?? starter still not turning. so we bumped it again. it fired up.
Drove down road, it stalls. now car is at my other yard. coz i aint got time on my hand to mess about with it at the moment.
The car stalling and not trying to fire up has made it alot more complicated than the intitial fault of it cutting out?
When the key is turned and it does do nothing. its just dead.  :undecided:
ANy sugesstions, going to get VAGCOM on it this weekend hopefully.  :evil:
Offline Callum_K
« Reply #6 on: 19 August 2013, 15:12 »
Ignition switch. Pretty simple to change. To test, unplug the wiring connector going in to the starter motor, and  try starting the car using a wire directly from the battery to one of the pins (can't remember which).
« Last Edit: 19 August 2013, 15:15 by Callum_K »
Offline Callum_K
« Reply #7 on: 19 August 2013, 15:17 »
Although I guess that might not cause it to cut out...not sure tbh! Was the crank sensor genuine?
« Reply #8 on: 19 August 2013, 15:25 »
Cranks sensor was bought from GSF. but i dont think its that. The symptoms dont show it could be that. will have to test each and every possible culprit once again. Damn  :sad:
« Reply #9 on: 19 August 2013, 21:46 »
Just been to see the poorly 8V.
Brother said he started the car at 5:30, and it started first turn of the key.
So I've just tried to start it now, and it's dead. All light come on as usual. But as soon as I turn the key there's no mechanical sound.
I can hear fuel pump priming.
Just had some jump leads to see if battery is f**ked, but no. Battery is fine.
So need to check all fuses and going to get direct power from battery going to the starter. See if it fires up. Also going to hook it up on vagcom.
Once I get the car to start, then I can start to investigate the cutting out problem.
Wish me luck  :smiley:
