Author Topic: diverter valve  (Read 14769 times)
Offline pryda
diverter valve
« on: 16 August 2013, 13:17 »
apologies if this has been asked begore. I'm using my phone and can't find search.
just had my car serviced at Awrsone GTi smf it needs a new diverter valve. just wondering if I shpuld buy another stock valve from the dealers or upgrade yo the Forge DV.
opinions please. cheers.
2009 MK6 GTi, Candy White 3dr, Stage 1 Revo, Milltek cat back, H&R SuperSport, RNS510, OSRAM kit
Unphased - NorthWest German/VAG/Retro Meet
Every 3rd Thursday Of The Month
http://www.un-phased.co.uk/
Offline Poached
Re: diverter valve
« Reply #1 on: 16 August 2013, 13:51 »
Oem valve. What revision failed?
How has it failed...Split rubber?
« Last Edit: 16 August 2013, 13:55 by Poached »
Offline pryda
Re: diverter valve
« Reply #2 on: 16 August 2013, 15:16 »
not sure what revision it is mate, or 100% on how its failed. plastic clips maybe? apparently it's causing boosting issues (although the car seems to be driving fine).
to be honest I'm more tempted by the OEM valve just because of the price difference.
Offline Poached
Re: diverter valve
« Reply #3 on: 16 August 2013, 17:06 »
I would find out. Your age vehicle is likely a D (No diaphragm) or G (More likely).
Usually the rubber can split leaking boost which you may not perceive if it's a small tear but the ECU would detect an issue if the requested pressure differed from the actual pressure produced.
If it was diagnosed through a fault stored on the car then they should be able to tell you the code which is usually P0299.
I believe the Forge may need periodic greasing.
Offline wigit
Re: diverter valve
« Reply #4 on: 16 August 2013, 17:19 »
it probably has got a tear, forge one is recommended to be serviced at something like 5k, i've seen one seize before that
also the position is a PINTA to get to on the tsi unlike the K04 cars
Offline Snoopy
  • Moderator
  • Geoff.
Re: diverter valve
« Reply #5 on: 16 August 2013, 17:47 »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline pryda
Re: diverter valve
« Reply #6 on: 16 August 2013, 18:40 »
thanks for the advice guys.
no error codes returned, just a leak spotted by the mechanic doing the service.
after looking in to it, gonna replace with the rev G and see how it holds up.
Offline RocketRossUK
Re: diverter valve
« Reply #7 on: 18 August 2013, 20:01 »
Shouldnt an 09 plate have a Rev G in it anyways?
Offline Snoopy
  • Moderator
  • Geoff.
Re: diverter valve
« Reply #8 on: 18 August 2013, 21:45 »
When you say leak what do you meen?
Unless he took it out and inspected it to see it was split the only other way would be by sound.
If he said oil leak on the diverter valve thats something else. Have a look at my oil leak thread if thats the case as i originally thought it was diverter valve.
Mk6 GTI  &  Mk1 GTI
Offline pryda
Re: diverter valve
« Reply #9 on: 19 August 2013, 17:58 »
thanks mate, that's exactly what he said. he also said it might not be the diverter. you got a link to the thread?
