Author Topic: diverter valve  (Read 14763 times)
Offline pryda
Re: diverter valve
« Reply #10 on: 19 August 2013, 18:42 »
When you say leak what do you meen?
Unless he took it out and inspected it to see it was split the only other way would be by sound.
If he said oil leak on the diverter valve thats something else. Have a look at my oil leak thread if thats the case as i originally thought it was diverter valve.
just read through your thread mate, looks like mine has the same symptoms (oil on the main air feed pipe etc.)
you have a PM :)
2009 MK6 GTi, Candy White 3dr, Stage 1 Revo, Milltek cat back, H&R SuperSport, RNS510, OSRAM kit
Unphased - NorthWest German/VAG/Retro Meet
Every 3rd Thursday Of The Month
http://www.un-phased.co.uk/
Offline RocketRossUK
Re: diverter valve
« Reply #11 on: 19 August 2013, 18:43 »
thanks mate, that's exactly what he said. he also said it might not be the diverter. you got a link to the thread?
Awesome are pretty decent guys, and it only take 5 mins to check. I bet he just whipped it out and saw a split. I thought my MK5 was fine till i got a new DV and then Wow...what a difference a new and working DV make.
Plus, Revo is a aggressive map, theres a good chance it has split it....
Offline Snoopy
  • Moderator
  • Geoff.
Re: diverter valve
« Reply #12 on: 19 August 2013, 19:10 »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline pryda
Re: diverter valve
« Reply #13 on: 19 August 2013, 19:57 »
Offline Snoopy
  • Moderator
  • Geoff.
Re: diverter valve
« Reply #14 on: 19 August 2013, 20:07 »
As I said in pms same as mine was.
Mk6 GTI  &  Mk1 GTI
Offline Snoopy
  • Moderator
  • Geoff.
Re: diverter valve
« Reply #15 on: 19 August 2013, 20:29 »
This is 99% of what i gave the dealer to help diagnose and fix mine. :evil:
Symptoms
• Oil leak
• Induction type air leak whistle at certain revs.
Oil leak, maybe possible causes,
• Crankcase ventilation systems small pipe and air intake pipe seals leaking causing a pressure issue which causes oil vapour to condense back into oil. (known issue to VW that can cause this type of leak that makes it look like a turbo issue)
• Diverter valve diaphragm split causing the crankcase ventilation system to think there is pressure present.
• Crankcase ventilation system valve failure.
• Turbo charger oil seals failure.
OIL HERE --- Under the car on the join between the turbo and diverter valve. -  06F 145 710G - Oil seems to be running down onto this from the top of the engine from the crankcase breathers small pipe. It is then running down onto this location
OIL HERE  --- Main air feed pipe join down the driver side of the engine bay. - 1K0 129 654 AP -
OIL HERE --- Small pipes join were it is connected to the air feed pipe on the top of the engine. This seems to be the source of the leak. It is wet and dripping / leaking oil.
Small pipe - 06J 103 213 - Air pipe -1K0 129 654 AP -
The small pipe is connected to the crankcase ventilation system - 06H 103 22A A - and fine oil separator - 06H 103 495 E -
THE FIX
They replaced the large intake pipe that i quoted the part number of in the PM.
Think it was 1K0 129 654 AP
« Last Edit: 19 August 2013, 20:41 by Snoopy »
Mk6 GTI  &  Mk1 GTI
Offline pryda
Re: diverter valve
« Reply #16 on: 19 August 2013, 20:54 »
great write up and thanks again mate for the advice.
I'll update the thread once the parts are ordered and fitted.
Offline pryda
Re: diverter valve
« Reply #17 on: 21 August 2013, 20:32 »
just to revisit this thread, looks like I'm going to pick up the Pipercross upgrade to replace the OEM part on payday next week...
http://www.dpmperformance.co.uk/pipercross-free-flow-intake-pipebr-golf-6-gti-20t-fsi-1008-p-8951.html
thoughts? :)
Offline Candy Man
Re: diverter valve
« Reply #18 on: 21 August 2013, 21:10 »
Is that a replacement intake pipe m8, i cant get the pic to load in :sad:
Cal
Offline pryda
Re: diverter valve
« Reply #19 on: 21 August 2013, 21:28 »
Cal
yeah it is mate...
"Works with OE airbox and other aftermarket filters
27% increase in airflow over the OE pipe
Smooth internal"
