Author Topic: major problem.codes included.happend twice now :(  (Read 2295 times)
Offline cooki
  • 1.8T AUM
Had no issues with the car at all.came back from an hours drive.jusrned the ignitoon back on 5 mins later to the engine spluttering and missfiring.was only 30 seconds from home so drove it home and also had no brakes.dont have vagcom or vcds at my disposal and my machanics phone is off lol sode law.
Any body got any ideas
Hope the vidoe works
http://static.photobucket.com/player.swf?file=http://vid64.photobucket.com/albums/h177/serzlee/20130815_155712.mp4
« Last Edit: 28 August 2013, 10:08 by cooki »
1.8T AUM,18"s,full koni suspension kit,forge split r on fully recirc,k&n induction with cold air feed,FMIC,r32 front,colour coded rear valance,black front and rear VW badges,5 door wind deflectors,boost gauge an volt metre in A pilla pod,full brushed alluminum net optic interior,full creame heated interior,
PLANS: catback exhaust&remapp her  :) :) :)
Offline barrym381
Re: major problem.video inclosed of engine noise
« Reply #1 on: 15 August 2013, 16:52 »
sound like a coil pack has shat its self or a blocked pick up pipe  :smiley:
Offline mike1990
« Reply #2 on: 15 August 2013, 17:06 »
Check the coil packs
Offline mcgee9t2
« Reply #3 on: 15 August 2013, 19:08 »
that was my initial thought too, sounds like a misfire from coilpack. ring vw and see if its been in for the recall or if your elageble for the recall
Offline cooki
  • 1.8T AUM
« Reply #4 on: 16 August 2013, 12:27 »
Hhhhhhm recall would be a bonus.machanic is picking it up today on hos recovery truck as I cant drive it as I have no brakes for some reason.
Ill ring vw sometime aswell.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 16 August 2013, 14:09 »
if you have no brakes as well as it running bad check the brake booster vac line
Offline harlemex
« Reply #6 on: 16 August 2013, 15:47 »
crikey, your engine sounds fcucked  :grin: :laugh:
Offline Screech16v
  • MK3 20vt AGU
« Reply #7 on: 16 August 2013, 22:00 »
This was my initial thought seeing as you have lost servo assist,ie big air leak in servo/pipe work to it.
« Reply #8 on: 16 August 2013, 22:04 »
I had the brake servo pipe split on mine and yes it ran rough but yours is a lot worse.
Duff coilpack would be my guess.
Offline mike1990
« Reply #9 on: 16 August 2013, 22:17 »
Don't pin your hopes up on the coilpack recall, this is a quote from one of my previous posts on this forum about the recall
Quote
took it in to the dealers today, after a prearranged appointment, 5 hours later collected the car.. my coil packs are the unaffected lot. No recall for me, not just that though, the women was listing all these "problems" my car had as if my wheels was about to fall off.. and gave me a sheet with the prices for these problems. One of them was the oil breather pipe had split - wanted £134.28 just to replace it  :angry: i don't think so. I then told her i was a trainee mechanic and her face suddenly dropped. For obvious reasons. Anyway, as i started to pull away from the dealership i noticed the car was running even more worse then what i took it in as, i knew what it was. Got back home to find one of the coil packs was unplugged  :shocked: so i'd been running on 2 cylinders and doing 18mpg just because they wanted more money it seems?  :angry: just trying to source a coil pack for my car then it will be running perfect again.
the day later i bought a brand new coilpack for £10 and it was running perfect again
