Author Topic: 16v starts and cuts out  (Read 4476 times)
Offline notenoughtime
« on: 13 August 2013, 20:55 »
Hey   :smiley:
sorry to jump right in and ask question straight away but i`m a bit stumped.  :rolleyes:
I`ve just bought a 1990 16v mk2 and tried starting it but nothing. checked pumps and both siezed so ordered both pumps fitted them and i have fuel pressure. metering unit was stuck solid so removed top and freed piston and is now freely moving. It now fires and runs for a second or two but thats about it.
any ideas guys
Thanks in advance, I`ll put a thread up of what i`ve just bought shortly  :wink:
Offline jezza16v
Re: 16v starts and cuts out
« Reply #1 on: 13 August 2013, 21:03 »
Can you keep it running with your foot on the pedal or does it cut out regardless?
Check for air leaks in the rubber intake pipe and the breather pipes, also below the intake pipe near the metering head there is an overrun cut off valve with some very iffy push fit connections, if any of those leak or the valve is not working properly it will stop the engine very quickly.
« Reply #2 on: 13 August 2013, 21:59 »
Thanks for your fast reply, No air leaks as far as i can see, anyway of bypassing the overrun valve for now so i can run it up to temp?
« Reply #3 on: 14 August 2013, 16:53 »
Anyone?
Tried again today but seems inj pump has packed up again! Unless problem with ecu?
Offline GeordieChap
« Reply #4 on: 14 August 2013, 17:25 »
Bit of a novice with cars but have a 16v and have read quite a bit about them if the car fires and runs for a couple of seconds and you have fuel pressure I would check the injectors are delivering fuel if the pumps had seized also I have read somewhere about the cold start valve with could be a faulty thermo time switch but I ain't a expert by any means
Offline raferackstraw
« Reply #5 on: 14 August 2013, 18:55 »
if both pumps had seized and you had to free off metering head piston then i would be looking at a fubar metering head, you need to check for fuel at injectors. check for spray and pattern, then get yourself a pressure guage and read this http://www.volvoclub.org.uk/tech/fuel_injection/k_jetronic.shtml
there are other sites google bosch k-jet
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
« Reply #6 on: 14 August 2013, 19:53 »
Cheers will check thread out
Offline Diamond Hell
  • Opinions я Us
« Reply #7 on: 15 August 2013, 14:59 »
This.
« Reply #8 on: 15 August 2013, 15:43 »
Tried again this morning and both new pumps fubard, so will get new ones again tomorrow any ideas on that guys?
  • Opinions я Us
« Reply #9 on: 15 August 2013, 16:32 »
You put the brand new pumps on and they were shot, or they were skanky old secondhand pumps?
I'm standing by the suggestion that the metering head is FUBAR.  They're sensitive petals and it being seized suggests it is beyond redemption.
