Author Topic: forge tip 3" maf?  (Read 2837 times)
Offline sharki786
  • GOT BOOST??
forge tip 3" maf?
« on: 11 August 2013, 11:06 »
could i buy the tip with a 3" maf or do i need to buy the adaptor?
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline brewey
Re: forge tip 3" maf?
« Reply #1 on: 11 August 2013, 12:28 »
Creation Motorsport do one for a 3inch maf. But other than that you'd need an adapter.
2000 1.8T ARZ - OEM+
Offline sharki786
  • GOT BOOST??
« Reply #2 on: 12 August 2013, 15:09 »
Which is better forge or creations? What do you guys recommend? 3" tip or 2.5" tip?
*****MK4 GTI T*****
Offline brewey
« Reply #3 on: 12 August 2013, 16:19 »
At the end of the day silicone is silicone. I've heard of people complain and rave about both. As for size it all depends on your setup. Obviously the bigger it is in there is more air.
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 12 August 2013, 19:21 »
Well im going to be buying a k03s with oil/water lines and what not. Also i have the honda s2k filter. Will defo habe remap but not just yet.
Charcoal canister delete and n75 delete.
Fmic
What else is there?
Oh yeah my mate said use tt/cupra injectors, is it worth it? 4bar fuel reg?
*****MK4 GTI T*****
Offline sharki786
  • GOT BOOST??
« Reply #5 on: 12 August 2013, 23:10 »
*****MK4 GTI T*****
Offline golfyste
  • Project track car
« Reply #6 on: 13 August 2013, 05:47 »
Rule #1 for tips - bigger is better!
Get the biggest one available
R-the have just started sellin a supersize tip or the k03s platform, that would definitely be your best bet.
As for "silicone is silicone" that's incorrect it all depends on the quality and how reinforced it is
The difference between a cm tip and a forge tip is quite big
The cm tip feels squishy and soft whereas the forge tip is hard retaining it shape under vacuume.
You need a full exhaust
Injectors
Possibly a fuel pump depending on the condition if yours
Also a good fmic with 2.5" pipe work
A fresh oe recirc or forge 007p
A vr6 clutch kit
And maybe 1 or 2 other things
Most I
Portably make sure it's all up to scratch before you take it for a map
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 13 August 2013, 07:40 »
Injectors
A vr6 clutch kit
Most I
Who has bought out the supersize silicone?
Also your very right about the cm and forge. Cm is squishy and forge is nice and hard.
Recieved my 2.5" miltek yesterday
Will be getting a fmic
Will be getting a k03s next weekend.
Which injectors? S3/tt/cupra r?
Which fuel pump? Cupra r again?
Whats most yoh can get from a k03 with fmic,full exhaust, s2k fikter and forge dv07? Some guy said he got 220 from it. Is he talking poo or can you get that?
*****MK4 GTI T*****
Offline mar_k
« Reply #8 on: 13 August 2013, 11:26 »
Different grades of silicone and thickness, The CM Tips and Pipes don't seem to withstand the heat in the bay and collapse, Seen it a few times now.
Offline golfyste
  • Project track car
« Reply #9 on: 13 August 2013, 11:54 »
It's r-tech who are selling the tips
What rngine code do you have?
A k03 maxes at about 200bhp where as the k03s maxes at 264bhp.
Cupra r fuel pump is good.
For the injectors. If you have a small port head (arz,aum,auq) then bam injectors will do
If you hae a agu then they don't fit so you need some other but I can never remember which ones haha
Think it may be calibra reds??
