Author Topic: Will these wheels fit?  (Read 8398 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Will these wheels fit?
« Reply #20 on: 10 August 2013, 22:54 »
If they are fitted with mk4 tyres you will need to change them to 195/45/16's or you will screw the gearing and speedo up.
tyres on my mk3 are 195/50/15 so if using the monty 2's i assume therefore i would need 195/40/16 tyres to keep my gearing/speedo accurate
Nope 195/45/16, 205/45/16 or 215/40/16 are the choices, 215/40 was the factory size on an Anni
nice one thanks for the useful info :afro:
2000 Mkiv GTi 1.8T AGU
Offline madsb
« Reply #21 on: 03 September 2013, 18:32 »
Update: Got new tyres fitted today, and going to have the wheels fitted on the car tomorrow. Are you guys sure that the vw emblems won't fit? I can't be bothered adding a spacer - it isn't legal here in Denmark, and don't want to go through the trouble of finding the correct one. However, I still really would like the VW emblems.. Maybe I can sand them back a bit and they will fit? I mean if the spacer only needs to be 3 mm, it shouldn't be that much? Cheers
Offline boneybradley
  • Back in a Mk3...
« Reply #22 on: 03 September 2013, 19:03 »
it's the caps that go over the rear bearing nuts that's foul, you may be able to knock them in a few mm (it may give a few mm to let you fit caps)
Offline Len
« Reply #23 on: 04 September 2013, 13:18 »
Thought you said my 205/45/16 were too big Wayne? :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
« Reply #24 on: 04 September 2013, 13:45 »
The thread in question was reference 17" wheels so might be best to check what your posting  :rolleyes:
Offline madsb
« Reply #25 on: 04 September 2013, 15:59 »
Looks like I'm gonna need 5mm spacers.. 3mm seems like it would be a bit too tight a fit... Is it a possibility to knock the wheel bearing caps a bit flat, or is that dangerous?
Offline Len
« Reply #26 on: 05 September 2013, 12:22 »
No Wayne you said my wheel/tyre combination was greater than the standard rolling radius.
Funny how you twist things when you are baltantly wrong!
www.sas.org.uk
www.the-ace.org.uk
« Reply #27 on: 05 September 2013, 21:38 »
Just for you, let me repost the info, I never siad greater but they are the wrong size, not that you will listen  :rolleyes:
Specification  Sidewall  Radius  Diameter  Circumference  Revs/Mile  Difference
205/50-15         4.0in  11.5in    23.1in         72.5in        874        0.0%
205/40-17         3.2in  11.7in    23.5in         73.7in        860        1.7%
215/40-17         3.4in  11.9in    23.8in         74.7in        848        3.0%
So as I said they will throw the speed / gearing out to a bigger degree against 205/40's
Offline gazareth
« Reply #28 on: 05 September 2013, 21:50 »
talking about people been wrong. what does blatantly mean? :grin:
