Author Topic: Will these wheels fit?  (Read 8395 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Will these wheels fit?
« Reply #10 on: 09 August 2013, 20:19 »
Surely it's better to hammer the centre caps in slightly flatter than not at all to avoid the risk of the bearings been exposed to excessive dirt and water.
Offline madsb
« Reply #11 on: 09 August 2013, 21:43 »
So 3mm spacers and they are a perfect fit on mk3?
Offline tweed
« Reply #12 on: 09 August 2013, 21:55 »
you may find the wheel centre's wont go on as they can foul the centre bearing cover thingy. 3mm spacers or removal both work
Yup agree, but that only affects the rear wheels though. I ran mine without the centre caps, no biggie.
sorry bud but that is a biggie and bad advise.
Just asking for grease to mix with water and bearings seizing up.
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #13 on: 10 August 2013, 10:56 »
Sorry just to clarify, I don't mean remove or run without the bearing covers, I meant the black plastic centres with the vw embloms on. I ran mine like this for over a year without any issues.
Surely those black plastic caps only serve a cosmetic use..?
« Reply #14 on: 10 August 2013, 11:20 »
Ah right, no issues running without those fitted. as you say they're simply cosmetic.
Offline madsb
« Reply #15 on: 10 August 2013, 11:59 »
.. Anyone mind verifying if 3mm spacers will make it a perfect fit? :) That means i can go buy them
Offline tweed
« Reply #16 on: 10 August 2013, 12:13 »
sorry. Yes thats fine
« Reply #17 on: 10 August 2013, 22:09 »
If they are fitted with mk4 tyres you will need to change them to 195/45/16's or you will screw the gearing and speedo up.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #18 on: 10 August 2013, 22:22 »
tyres on my mk3 are 195/50/15 so if using the monty 2's i assume therefore i would need 195/40/16 tyres to keep my gearing/speedo accurate
2000 Mkiv GTi 1.8T AGU
« Reply #19 on: 10 August 2013, 22:23 »
Nope 195/45/16, 205/45/16 or 215/40/16 are the choices, 215/40 was the factory size on an Anni
