Author Topic: MK2 golf and scirocco conversion  (Read 1719 times)
Offline dasachmo
« on: 15 August 2005, 17:58 »
soz, made a new topic coz this IS kinda different, erm.... basically, as i was saying, im trying to get this 85 mk 2 golf up to scratch, and i got hold of a scirocco steering wheel, from a A reg,
now im thinking of transferring the drivers seat from the scirocco to the golf, ( if it fits/works)... but can i transfer the steering wheel 2, im kinda worried coz if i wire it wrong or it aint meant to go, i dont wanna blow fuses or anything....
can anyone enlighten me.... thanx again in advance ...
Re: MK2 golf and scirocco conversion
« Reply #1 on: 15 August 2005, 19:53 »
Sirocco seats will fit perfectly and give you a lower driving position if you like which is nice :)
The steering wheel will almost defo fit, but the only issue you MIGHT have is that the steering column on the Golf has the large spline adaptor.  But I'm 99.99% sure it wasn't fitted till 87 at the earliest.
If it is fitted you can remove it, but its a total arse. Only attempt if you have a decent set of gear pullers :)
Offline dasachmo
« Reply #2 on: 16 August 2005, 01:39 »
cool, does that mean i can swap the speedo / rev counter bit, from teh scirrocco to the golf, coz i want one for the golf, and i can't get a GTI one?
« Reply #3 on: 16 August 2005, 09:21 »
I'm not sure about that,  if the plugs match up then it should fit no worries :)
Offline dasachmo
« Reply #4 on: 16 August 2005, 13:51 »
oooh, ooh, ooh, 1 last thing, soz, but when im doing switching like stuff with the dash and steering wheel, what kinda precuations do i have to take with regards to fuses? coz i dont wanna blow the electrics
« Reply #5 on: 16 August 2005, 14:03 »
Just take the negative lead off the battery, safest thing to do :)
