Author Topic: Gearbox output flange  (Read 2000 times)
Offline nightroamer
  • Mk3 16v
« on: 06 August 2013, 03:47 »
Hi all.
I have suffered a bit of a mechanical breakdown today.
Some how my drivers side inner cv has worked all the bolts loose and detached the driveshaft.
Luckily not too much damage done as I was only doing about 20. That said it has chipped my gearbox output flange.
Question is how are these removed? And is it an ok job or will it be quicker to remove and replace the gearbox. I have a spare box kicking about.
Thanks guys.
Offline Diamond Hell
  • Opinions я Us
Re: Gearbox output flange
« Reply #1 on: 06 August 2013, 19:34 »
IIRC remove the cap inside the flange and if it's an 020 I think there is a circlip, or it might be a bolt.  Buzz it off, or remove the cirlip, with the box tilted away from the flange you're removing, then pull it off.  Be careful that the seal is not damaged when you fit the replacement and away you go.
Offline nightroamer
  • Mk3 16v
« Reply #2 on: 06 August 2013, 23:19 »
happy days I hope! I think its circlip as I popped the cover off my spare gearbox in the garage last night a no screw/bolt. so I will get the car on stands late tomorrow afternoon and have a go. heres hopeing I dont either get stuck or have an oil leak after !!
Offline nightroamer
  • Mk3 16v
« Reply #3 on: 08 August 2013, 08:21 »
hi guys
ok I managed to remove the flange by remiving circlip and using 2 bolts and some blocks to carefully pull it out. it has the green oil seals and a big spring on the back of the flange.
also took flange off spare gearbox.  problem is I cannot compress it back in enough to get the circlip back on. any suggestions?
Offline Mr Blue
« Reply #4 on: 08 August 2013, 22:59 »
Large G clamps should do it. :smiley:
Also very common for the inner driveshafts to come lose. Take note people...check them bolts!
« Last Edit: 08 August 2013, 23:01 by Mr Blue »
Offline nightroamer
  • Mk3 16v
« Reply #5 on: 11 August 2013, 06:39 »
Thanks for the replies guys.
spent a hectic 2 days diagnosing and fixing this. In the end had to swap out the gear box as the bearing in the diff was damaged (where the cups go in).
managed to build a make shift tool to pull cups into diff using a ling bolt some wood and a large socket!!
bit gutted having to change gearbox but I guess I have the old one for spairs now.
