Author Topic: changing of clocks  (Read 2314 times)
Offline tom3218
changing of clocks
« on: 05 August 2013, 20:31 »
looking at putting a new set of clocks of my golf as mine are playing up,,,now can i just get any set out of a mk4 or do they have to be a certain type and do they need to be programmed after
Offline mar_k
Re: changing of clocks
« Reply #1 on: 05 August 2013, 20:35 »
You need to match the part number and they need coding.
Offline tom3218
« Reply #2 on: 05 August 2013, 20:40 »
thank you and were would i get them coded
Offline Rhyso
« Reply #3 on: 05 August 2013, 20:43 »
Dealers, VAG specilaist or maybe a local member with VAGCOM
Removing the clocks is a two minute job and the part number will be on the back  :smiley:
Offline tom3218
« Reply #4 on: 05 August 2013, 20:45 »
thanks again
Offline mar_k
« Reply #5 on: 05 August 2013, 20:47 »
The only thing with doing at the dealers is the mileage will not be changed,
What ever mileage is on the clocks you get will be whats shown.
My dad recently had his swapped as the red bit in the middle faded,
Dealers told him they where unable to change the mileage on used clocks as it was illegal to do so.
They  charged him £50 to code them.
We have since put the mileage back to what it was on the original clocks.
Offline Rhyso
« Reply #6 on: 05 August 2013, 22:32 »
You can change the mileage with VAG Tacho
Not sure how its illegal to re-do the mileage on used clocks to show what your car is actually on  :huh:
Its obviously illegal to knock miles off your current mileage but if you are simply putting in new clocks and setting the correct mileage I cant see the problem  :undecided:
Offline mar_k
« Reply #7 on: 06 August 2013, 17:16 »
Thats the thing Rhyso, They are not new clocks they are used. They said they would set the current mileage on
a set of new clocks but not used.
Again, I'm not clued up on the law but its what the dealer told us
Offline Rhyso
« Reply #8 on: 06 August 2013, 17:23 »
Im sure mileage correction people would do it.....  :smiley:
I know dealers can legally reset your delivery mileage on a new car; well they used to be able to do so as long as it was under 100 miles  :undecided:
Equally you would be fine if the used clocks showed MORE mileage than your current ones; its when they show less you'll end up in trouble  :lipsrsealed:
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 06 August 2013, 21:07 »
like rhys said the dealer tool can't change the mileage once its over 100km, legality has nothing to do with it you're just representing the true mileage of the car. If you have a laptop you can get the tools needed for less than £30 off ebay. Then you just need some research/reading and some bravery!
