Author Topic: Really dumb questions  (Read 2604 times)
Offline Ant
« on: 15 October 2003, 13:33 »
Ok, for most of you these question will really sound dumb, but I'm still new to all this GTi stuff and just don't know.
1) PSI, My GTi has 14" alloys on (not the originals though) how do I know what the PSI should be, is it constant regardless of the tyres (forces from the car) or do the tyres/dimentions make a difference?
2) Suspension, My GTi's been lowered, a little too low for comfortable driving with the missus (also pavement pulled my spoiler off) how do you change the ride height and or comfortablility, and which should I change to make the bumps a smoother?
Ok, bring it on :P
golfvr6
Re:Really dumb questions
« Reply #1 on: 15 October 2003, 14:07 »
1) Tyre pressures should be on your petrol cap.
2) You will probably have to change the suspension springs, unless the kit on there is adjustable.
Offline Ant
« Reply #2 on: 15 October 2003, 14:30 »
Ok I'll check that. Are type pressures are constant regardless of rim/tyres?
I'll check out the suspension try to get a make, I do know that when I jacked it up to check out the gear linkages it went a long way before the wheels left the ground.
Offline Slim Shady
  • Thrash her like a ginger step child
« Reply #3 on: 15 October 2003, 15:10 »
14" & 15"'s rule of thumb for a mk2 Gti  - 30/31 fronts  30/28 rears - would be the average (depending on wheel diametre)
"Scraping" - unless you have adjustables - you're gonna have to drive carefully over speed bumps/garage forecourts/garage ramps - (why the hell you driving up kerbs?).
You can buy new std springs - assuming you have a 30mm drop.
« Last Edit: 15 October 2003, 15:10 by Slim Shady »
Offline Ant
« Reply #4 on: 15 October 2003, 16:06 »
Wasn't the kerb just the access to drive way, camber combination, if I back in to drive way and drive out I have no problems.
Offline Slim Shady
« Reply #5 on: 16 October 2003, 09:51 »
Is this a question or a statement?
Sorry me no understandy the engleesh
« Last Edit: 16 October 2003, 09:52 by Slim Shady »
Offline Ant
« Reply #6 on: 16 October 2003, 15:04 »
Statement/explaination, as to "why the hell you driving up kerbs"
