Author Topic: Aircon Issues?  (Read 1572 times)
Offline tungmeister
  • MK4 GT TDI 150
Aircon Issues?
« on: 05 August 2013, 18:23 »
Hi guys, recently I've been doing some work on my dads Golf, I've got all the issues he had sorted apart from the air con. As far as I could tell it only needed regassing as he said it gradually got warmer until there was no coldness at all. I got one of those kits from halfords and regassed it. The pressue is correct and it doesn't seem to be leaking anywhere but it just isn't getting colder. I can hear the pump engage and I've checked all the fuses, the fans come on fine etc so I'm not really sure where to look next. The only thing that seems different to mine is that when the air con is engaged I can hear noises from the blower area like moving liquid, which I'm presuming is the refrigerant moving through the evaporator or could this be an issue? anyone any Ideas? I've already posted this over at ukmkivs but my dad is harassing me about it so i figured I'd as on here as well  :whistle:
Offline james2
  • No scammers please.
Re: Aircon Issues?
« Reply #1 on: 05 August 2013, 19:50 »
I would try and refill it again on a cold morning. Read the comments on halfords web site. Its like trying to refill a lighter with gas ,but the lighters warm so only a tiny bit of gas goes into it, if done when cold you can fill the lighter right up with gas. Worth a try.  :whistle:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Re: Aircon Issues?
« Reply #2 on: 11 August 2013, 10:31 »
Just take it to a specialist for leak testing and regassing, Halfords kit is a waste of time and money, air con is not really a diy fix.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Aircon Issues?
« Reply #3 on: 11 August 2013, 10:46 »
As above, there's more to it than just filling it up yourself
Offline brewey
Re: Aircon Issues?
« Reply #4 on: 11 August 2013, 12:36 »
Isn't it only around 40-50 quid to get done by a specialist anyways? Although I hate taking my car there, Kwikfit will give you it free if they cannot get it to a certain percentage lower in temperature than when you came in.
2000 1.8T ARZ - OEM+
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Aircon Issues?
« Reply #5 on: 11 August 2013, 13:02 »
Kwikfit will probably bugger it up meaning they cannot get it to a certain percentage lower in temperature than when you came in.
Fixed :afro:
Re: Aircon Issues?
« Reply #6 on: 11 August 2013, 14:18 »
Due to time issues I had kwik fit sort mine before the holiday, it is still working at the moment.
They charge £59 but test for free.
Offline brewey
Re: Aircon Issues?
« Reply #7 on: 11 August 2013, 14:47 »
Fixed :afro:
Lol. Good work probably more accurate.
