Author Topic: Air Con Condensor  (Read 2314 times)
Offline M3 SHAM
Air Con Condensor
« on: 05 August 2013, 15:02 »
Seems my GT requires a new air con condensor.  Anyone know where the best place is to purchase one of these (other than stealers or TPS) and also how much i should be looking to pay?
Also is possible to recondition the existing air-con condensor and would this be advisable?
Thanks
Offline Ginge 35Edition
Re: Air Con Condensor
« Reply #1 on: 05 August 2013, 18:26 »
How olds the car, my 35 had its done before I sold it and they reckoned it was a common fault. Even if its Over three years old you might get some 'good will'?
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #2 on: 05 August 2013, 19:01 »
Mine was damaged when the car was about 7 months old, new one was about £120 from the Internet
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #3 on: 05 August 2013, 19:32 »
Try german ebay.
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline M3 SHAM
« Reply #4 on: 06 August 2013, 16:55 »
Mine is a 2009 reg, i have heard it is a common fault as well
« Reply #5 on: 06 August 2013, 17:23 »
Write to VW uk and see if you can get some good will.
Offline andyr
« Reply #6 on: 06 August 2013, 21:29 »
now are we talking air con compressor...... or condenser (a rad mounted at the front of the car to dissipate the heat from the system.... which could be prone to damage from stone chips etc???)  :undecided:
Mk VI Black Pearl GTD.... No Frills, replaced a Black Pearl PD150 Bora, which in turn replaced a Dragon Green VR6 which followed a Dusty Mauve MK III 8v Gti.
Offline M3 SHAM
« Reply #7 on: 07 August 2013, 13:44 »
Not so sure now...
It looks like a cylinder and is mounted behind the radiator.  Connects to a plug and has what looks like a bolt that goes through the middle of it?
« Reply #8 on: 07 August 2013, 18:56 »
Think that's the compressor?
Offline andyr
« Reply #9 on: 07 August 2013, 20:18 »
Sounds like it doesn't it. Does it have a pulley on the left side with a belt around it? If so, it's the compressor  :smiley:
