Author Topic: Immobiliser Active!  (Read 2659 times)
Offline GTGirl
Immobiliser Active!
« on: 05 August 2013, 09:44 »
Hi all...
So I've had the car for just over 2 weeks and all is fantastic, however over the weekend within 24 hours the immobiliser active warning came up twice. Both times removed the key, tried again and she started perfectly. I'm just wondering if it could be something as simple as my key? It is seriously loose within the fob and has a major wobble going on. Took the fob apart and all the plastic is worn right down at the part the key blade sits.
I have been told it could be something to do with the connectors on the back of the instrument cluster or the connector for the ignition switch pickup coil. These are still to be checked.
So i am wondering how likely it would be that the key is causing the problem?
Offline GTi_James
Re: Immobiliser Active!
« Reply #1 on: 05 August 2013, 13:55 »
where in suffolk you situated? sounds like knackered fob tbh with you. you not got a spare one?
Offline GTGirl
« Reply #2 on: 06 August 2013, 07:00 »
Thanks :) I have ordered one and it should be here within a few days.
I'm in Ipswich, how about you?
Offline GTi_James
« Reply #3 on: 06 August 2013, 13:34 »
working AXA in ipswich lol
Offline rfn_hodgson
« Reply #4 on: 06 August 2013, 22:53 »
im having the same problem but my key fob is in good condition and sadly i only have to one :( any other ideas what it could be??
sorry to pinch your thread gt girl :)
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
