Author Topic: Cross member bush change  (Read 6241 times)
Offline Diluxe
« on: 02 August 2013, 19:22 »
Got some new poly bushes to put in the front cross member
How do I remove these metal plates to push the original bushes out?
1997 16V
VW BUSH
Re: Cross member bush change
« Reply #1 on: 02 August 2013, 21:09 »
Click on the pic to enlarge.
Get choppy with a hacsaw and order the new washer housing bolts etc from VW
engine carrier with rubber mounting
/ AAA
(1)   1H0199200L
/ ecomatic 1Y
2   191199233
bonded rubber mounting / F >> 1H-PW080 000* / F >> 1H-PB010 000*
2   1H0199233A
bonded rubber mounting / F 1H-PW080 001>>* / F 1H-PB010 001>>*
2A   1H0411363A
rubber mounting
/ ecomatic: 1Y
2B   357199501
balance weight
/ 1Z
2C   N 10315601
hexagonal head bolt
AM8X40 / 1Z
3   1H0199187A
arm
4   1H0199175A
washer
15X50X2,5 /
5   N 10246501
hexagon head bolt c/w shoulder
M10X62 /
6   1H0199609K
/ AAA
(6)   1H0199609E
/ ABD,ABU
(6)   1H0199609F
/ AAM,ABS
(6)   1H0199609B
/ 1Y,AAZ
(6)   1H0199609J
/ 1Z
(6)   1H0199609G
bonded rubber mounting / F >> 1H-RW240 000* / F >> 1H-RB060 000*
/ 2E,AEK ABF
(6)   1H0199609J
bonded rubber mounting / F 1H-RW240 001>>* / F 1H-RB060 001>>*
/ ABF
7   1H0199635
limit stop
/ AAA
8   N 90074401
hexagon nut, self-locking
M8 / AAA
9   N 10230201
shouldered bolt
M10X32 /
(9)   N 10070403
hexagon head bolt c/w shoulder / bonded rubber mounting
M10X30 front, upper /
(10)   1H0199273J
console
front / ABD,ABU
(10)   1H0199273A
console
front / manual- gearbox: AAM,ABS,2E, 1Y,AAZ,AEK
(10)   1H0199273B
console
front / manual- gearbox: ABF,1Z
(10)   1H0199273C
console
front / automatic: ABS,AAM,2E, AAZ,1Z,AEK
10   1H0199273D
console
front / manual- gearbox: AAA
(10)   357199273C
console
front / automatic AAA
(11)   N 0195324
M10X70B / ABD,ABU
(11)   N 10048703
hexagonal head bolt
M10X60 / manual- gearbox: AAM,ABS,2E, 1Y,AAZ,AEK
11   N 10241603
AM10X45-SW16 / manual- gearbox: AAA,ABF,1Z
(12)   N 90489701
hexagon socket head bolt with collar
M10X60 / automatic: AAA
13   N 10261302
hexagonal nut
M10 / ABD,ABU
(14)   1H0199315AA
sub-frame
15   1H0199322H
balance weight
/ 2E,ABF,ABS, AAM,ABD
15   1H0199322H
balance weight
/ ABU,AEK
(15)   1H0199322J
balance weight
/ 1Y,AAZ,1Z
16   N 10001204
hexagonal head bolt
M8X55 /
17   N 90226403
shouldered hex. nut, self-locking
M8 /
(18)   191199381A
rear / ABD,ABU
18   357199402B
rear / 2E,ABS,AAM, 1Y,AAZ,AEK
(18)   3A0199402
/ AAA,ABF,1Z
19   N 0195334
M8X20 /
(20)   1H0199262A
right rear / 1Y, automatic: AAZ,ABS
(20)   1H0199262B
right rear / manual- gearbox: AAZ
20   1H0199262K
right rear / AAA
(20)   1H0199262E
right rear / ABD,ABU
(20)   1H0199262A
right rear / manual- gearbox: ABS,AAM, automatic: 2E,AAM,AEK
(20)   1H0199262B
right rear / ABF, manual- gearbox: 2E,AEK
(20)   1H0199262L
hydro-mounting
right rear / 1Z
(21)   1H0199354L
console
right / ABD,ABU
(21)   1H0199354K
console
right / manual- gearbox: AAM,ABS,2E, 1Y,AAZ,AEK
(21)   1H0199354H
console
right / manual- gearbox: ABF,1Z
(21)   1H0199354J
console
right / automatic: 2E,ABS,AAM, AAZ,1Z
(21)   1H0199354J
console
right / automatic: AEK
21   357199354J
console
right / manual- gearbox: AAA
(21)   357199354K
console
right / automatic: AAA
22   1H0199456
shield
(22)   1H0199456B
shield
lhd / 1Z,AEK manual- gearbox: ABF
(22)   1H2199398
shield
rhd / manual- gearbox: ABF
23   N 90335004
clamping washer
5X30 rhd / manual- gearbox: ABF
(23)   1H0199442
clips
/ 1Z,AEK
-   N 01021527
hexagonal head bolt
M6X15 rhd / manual- gearbox: ABF
23   N 90335004
clamping washer / F >> 1H-RW100 000* / F >> 1H-RB020 000* / F >> 1H-RP040 000*
5X30 / AAA ABF
(23)   1H0199442
clips / F 1H-RW100 001>>* / F 1H-RB040 001>>* / F 1H-RP020 001>>*
/ ABF
24   N 90553202
double stud with hexagon drive
BM10X58/M8X12 /
(25)   N 90201502
allen key head bolt
M10X32 / ABD,ABU
(25)   N 10195301
M8X35 / 2E,ABF,ABS, AAM,1Y,AAZ
(25)   N 0195033
hexagonal head bolt
M8X35 / 1Z AEK
25   N 10268501
hexagonal head bolt
AM10X42-V-SW16 / AAA
26   N 10175102
M10X52 / AAA
(26)   N 0195043
hexagonal head bolt
BM8X45 / ABF,ABS,AAM, 2E,1Y,AAZ, 1Z,AEK
(27)   191199353D
console
left / ABD,ABU
(27)   1H0199353D
console / also use:
left >>1H-RW100000 >>1H-RB020000 >>1H-RP040000 N 101 028 03 / AAM,ABS,2E, 1Y,AAZ,AEK
27   357199353A
console
left / AAA,ABF,1Z
(27)   357199353B
console
left / automatic
(28)   N 0195324
M10X70B / ABD,ABU
(28)   N 10102803
hexagonal head bolt
BM8X98-PC / AAM,ABS,2E, 1Y,AAZ,AEK
28   N 10067003
M8X92-V / AAA,ABF,1Z
(29)   N 0195324
M10X70B / ABD,ABU
29   N 0195042
M8X45B / AAA,ABF,1Z
(29)   N 10195301
M8X35 / automatic
30   N 10261302
hexagonal nut
M10 / ABD,ABU
(31)   191199358A
support for transmission
4-speed man. gearbox / ABD,ABU
(31)   191199358D
5-speed man. gearbox / ABD,ABU
(31)   191199358B
31   357199356
(32)   N 0195324
M10X70B / ABD,AAM,ABS, 2E,1Y,AAZ, ABU
32   N 10048703
hexagonal head bolt
M10X60 / AAA,ABF,1Z
(33)   N 10261302
hexagonal nut
M10 / ABD,ABU
33   N 10155207
hexagonal nut
M10-SW16 / AAM,ABS,2E, 1Y,AAZ
34   N 10241603
AM10X45-SW16 /
35   N 10257501
M10X24 /
36   N 10207803
hexagonal head bolt
M12X1,5X78 /
37   N 10209603
M12X1,5X65 /
38   037199307
support for engine/transmiss.
/ ABF
39   N 10238202
allen key head bolt (combi)
M10X60 / ABF
40   N 90572601
M10X95 / ABF
41   N 90331604
« Last Edit: 02 August 2013, 21:12 by VW BUSH »
Offline gazareth
« Reply #2 on: 02 August 2013, 21:29 »
surely you don't have to chop them up???
VW BUSH
« Reply #3 on: 02 August 2013, 22:59 »
no but its damn quick with new bits and an angle grinder :grin:
Offline Diluxe
« Reply #4 on: 02 August 2013, 23:57 »
So from the diagram , if I snip through no.4 and re-order that , I should be good right ?
1997 16V
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #5 on: 03 August 2013, 08:38 »
Get hacking,  replacements aren't going cost much at all and will save you  wasting ttime on trying to separate the old ones without damaging them.
Offline gazareth
« Reply #6 on: 03 August 2013, 14:16 »
but some people have lots of time but little money :huh:
Offline Diluxe
« Reply #7 on: 04 August 2013, 08:33 »
So you guys are saying cut through the sleeve protruding from #3, then buy#3and #4 and refit with the replacement poly bush?
1997 16V
Offline vwscottie
« Reply #8 on: 05 August 2013, 00:14 »
You could heat item 4 with a blow torch to expand it but it'll be a bit messy with the rubber bush likely to catch fire
