Author Topic: MK7 GTD - Real Life MPG  (Read 439960 times)
Offline monkeyhanger
Re: MK7 GTD - Real Life MPG
« Reply #540 on: 24 January 2014, 13:20 »
^ The old PD engines seem to have constant economy for me - no difference whether you clogged it or drove like a nun.
Offline AdmiralGant
« Reply #541 on: 24 January 2014, 21:05 »
I left Suffolk Thursday morning with around 70 miles on the odo and drove to Gloucestershire in Eco Mode and ED on the gearbox and it averaged 48.3mpg which I was quite happy with.
Came back today and now showing around 550 miles and drove in Comfort mode with the gearbox mainly sat in 6 manual and it averaged 49mpg.
Considering the engine is still working up and the driving was quite swift there and back - well impressed!
I guess however some shorter trips in Sport Programme could see a significant drop  :rolleyes:
Fleet
On Order - BMW 330d M Sport with M Sport Plus pack, voodoo lights, adaptive cruise, dampers - Battleship
Decommissioned 20/1/16 - GTD Mk 7 DSG 5dr Carbon Grey, ACC, Winter Pack, Class - Pocket Battleship (Flagship) - commissioned 21/1/14
Seat Ibiza FR TDI 130, Flame Red, Class - Frigate - commissioned 01/09/07
Suzuki Jimny 1.3 JLX+, quasar grey, Class - destroyer - commissioned 30/11/08
Suzuki Bandit 650, red, Class - covette - commissioned 01/09/05
Offline Gordor
« Reply #542 on: 24 January 2014, 21:24 »
I'm telling myself to stop worrying about the mpg....or chop the GTD for a blue motion. I got exactly 50 mpg on the way home tonight but bored with the drive. No happy medium maybe?
GTD Pure White : 19" Santiago's : Winter Pack : Dynaudio : Park Assist : High Beam Assist
« Reply #543 on: 24 January 2014, 21:41 »
Keep telling myself the same thing - but the mpg reading on the MFD is hard to ignore. Sometimes I wish it wasn't there - ignorance is bliss!
Offline AdmiralGant
« Reply #544 on: 25 January 2014, 18:41 »
Hi Monkeyhanger - you have mentioned regen in a couple of your posts. Can you help me and advise what that is please? Sorry only got the car this week and fairly new to the forum. Thanks.
Fleet
« Reply #545 on: 25 January 2014, 19:19 »
Regeneration of the DPF. There is a multilayered ceramic block (think of it like a honeycomb, but it's structure is more uniform than that) just after the engine manifold, at the start of  the exhaust system through which the exhaust gases flow. It collects all the soot generated by the engine and stores it so you don't get that sooty black cloud pouring from your exhaust that can be seen in older diesels.
At intervals the DPF needs to be cleared so the exhaust back pressure doesn't build up.
If you do regular moderately long journeys, the engine generates enough heat for the DPF to heat up and burn off the soot. This is passive regeneration, if you do more than 15 miles per journey then this should suffice to keep the DPF clear, this can't happen until the engine is up to full operating temperature.
Then there is active regeneration. Basically the DPF is loaded with soot to the point where the car tries to force a regen because you persistently haven't met the conditions for a passive regen. It takes steps to force the DPF up to temperature required for regen by introducing fuel into it to burn and generate heat independently of the engine.
During active regen the car is running (in my experience) about 15% thirstier than normal. When the DPF is clean, post regen, the car will be running at its most economical, and it starts to dip towards the point at which regen is required. On my 12 mile commute, I can see 47mpg for the journey when the DPF is clean, dipping down to about 45mpg when a regen is imminent, and 41mpg when undergoing an active regen.
Offline AdmiralGant
« Reply #546 on: 25 January 2014, 19:42 »
Thanks Monkeyhanger - blimey these cars are hi tec - had no idea that was fitted, I guess you have no idea when it happens other than the fuel consumption dip.
I am still getting over using the cruise control today and letting the car have the speed and brakes with me just steering - nearly a week on I must say very impressed.
I'll probably find something else to ask you in a few days - please just humour me !!   :shocked:
Fleet
« Reply #547 on: 26 January 2014, 12:40 »
Just filled up today. Took a small risk on range getting the missus to work at 6am, I went 5 miles beyond "0 miles" on the MFD because there were no fuel stations open around me (they all seem to open at 7am on a Sunday). I was literally the needle's width off the white empty line in the fuel gauge.
MFD mpg ave for the tank was 44.1mpg, and actual fill was 46.7L on 450 miles - 44.1mpg. That was on Esso.
For the first time since owning my Scirocco, I have given Shell fuelsave a go. It used to be a solid 4p a litre more than the Morissons 1/2 a mile away, now it's dropped to 1p over (now at 135.9p/L).
On top of that they've got 5p a litre off when you buy 2 certain products. Opted for 2 x 100g bags of mini eggs which ended up adding only 30p to the cost of the fuel on its own.
Offline Gordor
« Reply #548 on: 26 January 2014, 16:42 »
That sounds like a great deal....keep us updated on the fuel save will you?
Alternatively I'm turning the central display unit off and using tippex to show a constant 54.3  :laugh:
Offline Damo66
« Reply #549 on: 26 January 2014, 19:52 »
Set the central display at MPH and enjoy driving the car, if you had ordered the GTI you would end you up averaging around 30mpg whereas the GTD will average well over 40mpg  :smiley:
Beetle (1975)
MK2 Golf GTI 16V
MK3 Golf GTI
Corrado G60
MK3 VR6
Passat Sport PDI
MK4 Golf GTI PDI 150
MK5 GTDI 140
MK5 Golf GTI
MK6 Golf R
MK6 Golf GTD
MK6 Golf GTI Ed 35
Beetle Sport TDI
MK7 Golf GTD
