Author Topic: MK7 GTD - Real Life MPG  (Read 439706 times)
Offline AlanH
Re: MK7 GTD - Real Life MPG
« Reply #530 on: 22 January 2014, 19:57 »
Find a motorway!
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline dippy_x
« Reply #531 on: 22 January 2014, 20:00 »
Had my first noticeable regen today.  Popped into my folks who are about 8 miles into my 11 miles trip home and noticed the fan was still running loud after switching off the ignition.  It was off by the time I got back (about 30 mins later).  Mpg when I got home was 47.5 - so not as bad as I thought it was going to be.
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
Offline mon2s
« Reply #532 on: 23 January 2014, 07:05 »
Just after work very short commute back home, I never seem to break 50 mpg barrier for the longest time. My commute mainly consists of some mixture of A and B roads, average speed of 17 mph pretty much tells the whole story.
Don't know what I could be doing wrong but I would love to see 55+ at least once.
49mpg on am 8 mile run where the car won't even get warm, in a fair bit of traffic judging by the ave speed, looks impressive from where I'm standing.  Get it on a proper run and see what return you get.
Offline Misterp
« Reply #533 on: 23 January 2014, 09:29 »
I'm with mon2s, mine is a similar commute I'm lucky if I get more than 42-43.
Golf GTD mk7 DSG pearl black - collected 25 September 2013.
Offline AlanH
« Reply #534 on: 23 January 2014, 09:36 »
Sounds pretty healthy to me - try a motorway trip and you should easily see low 50's.
Offline jivemonkey
« Reply #535 on: 23 January 2014, 10:13 »
Well, it was -2 when setting out today and fully iced over. Sat on my driveway for 5 minutes de-icing before moving off - traffic horrendous and accident on my main route added 10 minutes to my journey.
The figures speak for themselves..
Winter winter go away!
Today was slightly "warmer", and the traffic not quite as bad as usual so only creeping along for around 5 minutes. Quite happy with the direction it's going, should do quite well in the summer.
« Last Edit: 23 January 2014, 10:36 by jivemonkey »
Golf VII GTD | 5dr DSG | Deep Pearl Black | Dynaudio | Winter Pack | High Beam Assist | "Advanced" Phone Prep
Offline idczar
« Reply #536 on: 23 January 2014, 21:39 »
After work tonight, took some detour travelled along M3, M25, M4, then couple of A roads. Not terribly cold outside around 6 degrees. Travelled extremely carefully without using ACC as much as I could, just remembering to do constant throttling and here is the result.
Offline jivemonkey
« Reply #537 on: 24 January 2014, 09:03 »
Now that's promising, how many do you have on the clock at the moment? There's definitely a sweet spot for MPG lower down the speedo, I see your average was around 30mph but how fast were you cruising? I'm guessing 50-60?
Offline monkeyhanger
« Reply #538 on: 24 January 2014, 09:49 »
About 60mph is the sweet spot for best mpg most driving conditions – fast enough for the engine to be comfortable in 6th gear in all conditions without having to rely on putting a disproportionate amount of fuel in to maintain high torque in any situation to keep you in 6th e.g. going up a hill etc, the engine will be doing about 1650 revs. The air resistance is still pretty linear with speed up to 60mph, after that the car starts to require disproportionately more effort to overcome it as the speed increases. Traditionally 56mph was the optimum speed for fuel economy, but for a high geared TDI, it’s a bit higher than that as I’m sure you wouldn’t take a really steep hill in 6th at 55mph, doing only 1500rpm, you’d end up knocking it down to 5th, but on the flat, 55mph/6th will be great for mpg.
There are times when knocking down a gear will yield better mpg. I find that even though my GTD is happy to sit in 6th to do a constant 40mph, 5th gear is more economical for me than 6th up to about 43mpg on the flat and maybe up to 50mph up a moderate hill. The gear change prompt doesn’t seem intelligent enough to always give you the right answer – it seems to take only  gear and speed into account, rather than engine effort in certain situations, although it does seem to tweak the speeds for gear change up when the car is undergoing an active regen.
Offline mcmaddy
« Reply #539 on: 24 January 2014, 11:40 »
82mph used to be the sweet spot on my old Leon 1.9 fr. used to average high 50's low 60's on a run!
