Author Topic: Audi needs new rear damper  (Read 1622 times)
Offline Sam
  • Sam I am
« on: 01 August 2013, 09:49 »
Hey guys, one of my rear dampers is weeping and needs replacing. Can I get away with just a straight swap or should I do both? Cheers, Sam
Offline dragonfly
Re: Audi needs new rear damper
« Reply #1 on: 01 August 2013, 10:00 »
Do both as the other will fail at some point.  Plus you won't have any issues with handling.
« Last Edit: 01 August 2013, 11:10 by dragonfly »
Offline Sam
  • Sam I am
« Reply #2 on: 01 August 2013, 10:03 »
I'm kinda asking this from a 'will it kill me' stance rather than 'will it effect my handling at all?'. I simply can't afford 2 rear dampners on top of all the other stuff I have had to order due to my car been completely f**ked.
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 01 August 2013, 11:49 »
So put a secondhand one in for now and replace the pair when you can afford it, you tight-assed pikey git.
Offline Sam
  • Sam I am
« Reply #4 on: 01 August 2013, 13:02 »
Oi!... I'm not a git
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 01 August 2013, 19:49 »
Yes Sam, you can get away fitting just the one to get you by, though the other shocker wont be far behind before it leaks...
Thon
Offline Bellend
« Reply #6 on: 01 August 2013, 20:45 »
Things can get very twitchy with just one shock gone. Clio would lose back end without warning when turning left when the right hand rear blue and after just changing the one while at Alton Towers it did it going right a tad. Not as bad as before but was perfect after I swapped the other.
Also cheap judt doesn't last the same as a decent pair.
Where all my moneys went.
Offline JC
  • Back in the North.
« Reply #7 on: 01 August 2013, 22:46 »
How do you know they were replaced as a pair before ?
Or if the other side has even been replaced just before he bought it ?
Just saying  :whistle:
Offline gazareth
« Reply #8 on: 01 August 2013, 22:55 »
just what I was gona say :rolleyes:
