Author Topic: Engine runs, then cuts out  (Read 1264 times)
Offline Ant1981
  • Feed me, prod me
« on: 31 July 2013, 09:23 »
Hello chaps,
I started my engine this morning (2002 AUM) and it cut out after a few moments. I started again a few more times and the same thing has happened. I notice a strong smell of fuel.
My fault code reader doesn't read any faults but on the readiness check comes up with the following failures,
Evap sys: Fail
SecAirSys: Fail
O2Sensor: Fail
Heated O2: Fail
Ok, had an O2 failure some years back, had a strong smell of fuel, yet the car did run, but I don't recall the other failures happening before *scratches head*
Any help or guidance? Cheers.
'09 Kawasaki Ninja ZX-6R
Offline Nino
Re: Engine runs, then cuts out
« Reply #1 on: 31 July 2013, 10:37 »
My AUM did this twice but both times I noticed that the immbiliser light was showing on the dash.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Ant1981
  • Feed me, prod me
« Reply #2 on: 31 July 2013, 11:05 »
Mines not doing that, different symptoms and notable strong smell of fuel.
I had a spare temp sensor knocking about, so put that in and the car now stays running, although not perfectly, but it's been lumpy and bumpy for a while anyway.
Have code 16486 is present now, which is a MAF low signal code, so could be something to do with it. It's certainly given me problems in the past, so may not be such a bad idea to replace it now to eliminate it.
Offline Rhyso
« Reply #3 on: 31 July 2013, 11:11 »
Does it run any better with the MAF unplugged?
Offline Ant1981
  • Feed me, prod me
« Reply #4 on: 31 July 2013, 11:19 »
Can't really say that it does, though I've not actually driven it, I let it idle and just moved it about in case it stalls again. Maybe it's because I've let the car warm up now that it appears better.
Perhaps I ought to investigate the supply to heat the O2 sensors too seeing as the readiness check says that failed.
Offline Ant1981
  • Feed me, prod me
« Reply #5 on: 31 July 2013, 11:26 »
Just to add, the readiness tests in post 1 which came back as 'failed', are not actually giving me any fault codes as a failed device.
