Author Topic: Loss of power...still!  (Read 1394 times)
Offline ryanbrook
« on: 30 July 2013, 18:15 »
I am getting an occasional loss of power, sometimes I will start it and it will have power loss, turn the engine off and on again and power is back. I am getting the camshaft position sensor - implausible signal code, but the sensor has been changed and timing checked twice. Any ideas. Car is 1.6
Offline navmk4gti
Re: Loss of power...still!
« Reply #1 on: 30 July 2013, 18:35 »
Faulty sensor have you not changed it??
Offline ryanbrook
« Reply #2 on: 30 July 2013, 19:08 »
Sensor been changed mate.
Offline navmk4gti
« Reply #3 on: 30 July 2013, 19:24 »
U use a proper one from dealers or ebay jobied it?
Offline ryanbrook
« Reply #4 on: 30 July 2013, 19:28 »
Garage Did it. Was from euro car parts.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 30 July 2013, 19:45 »
this is limp mode. Have you cleared the code since fitting the new sensor?
Offline ryanbrook
« Reply #6 on: 30 July 2013, 19:48 »
I have indeed. Keeps coming back
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 30 July 2013, 20:08 »
might be a fault with the plug or wiring itself then mate, might need an auto electrician to check it unless someone here knows the resistance values?
Offline ryanbrook
« Reply #8 on: 30 July 2013, 22:07 »
That's what a was thinking mate. Wiring issue. Because with it only been intermittent there may be a short somewhere.
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 31 July 2013, 20:48 »
implausible signal could mean your timing belt is off a tooth or two, or it might just be a sh!t quality sensor.
