Author Topic: Silicone tip  (Read 3372 times)
Offline Screech16v
  • MK3 20vt AGU
Silicone tip
« on: 28 July 2013, 22:56 »
Hi guys ive just purchased an sfs silicone tip  ,will I actually notice any difference changing from the standard item,ive heard standard is restrictive,my engine is agu ko3,it has the following mods,piper induction kit ,remapped, 3"downpipe decat 2.5 s/s single box system,front mount ic,forge 008, cheers
« Last Edit: 28 July 2013, 23:15 by Screech16v »
Offline tg1
Re: Silicone tip
« Reply #1 on: 29 July 2013, 18:18 »
yeah you will, pig to fit without ramps
Offline Screech16v
  • MK3 20vt AGU
Re: Silicone tip
« Reply #2 on: 29 July 2013, 18:42 »
Cheers tg so its worth the hastle then  :smiley:
Offline rfn_hodgson
Re: Silicone tip
« Reply #3 on: 30 July 2013, 12:42 »
i noticed on my AUQ straight away and yea its a tw@t to fit but its worth it
VW Golf MK4 1.8 Turbo AUQ 203 BHP-more now :) , ultimate vacuum delete, Forgre 007p-new piston, Oil catch can, s3 boost set up, FMIC, silicone TIP, full turbo back exhaust, stage 1 map, lowered on V-maxx coilovers  audi tt Quattro alloys
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
Re: Silicone tip
« Reply #4 on: 30 July 2013, 14:16 »
Yeah I noticed a difference on my AGU, the pick up is a lot smoother :grin:
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline Nino
Re: Silicone tip
« Reply #5 on: 30 July 2013, 15:00 »
yep i notice a difference also, however set aside 2-3 hours and just when you think you cannot get it on and your ready to give up, pop it goes on lol
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline 52GTIPETE
Re: Silicone tip
« Reply #6 on: 30 July 2013, 15:39 »
It is a bugger to fit but if you get the 3" inch end and put on an S3 bam engine MAF housing you get a lot more air intake.
Offline Screech16v
  • MK3 20vt AGU
Re: Silicone tip
« Reply #7 on: 30 July 2013, 23:16 »
2-3 hours? what,surely not,did you take the engine out to fit it  :laugh: its only a bolt and some clips how can this be,im going to do it tomorrow
Offline Granta Gti
Re: Silicone tip
« Reply #8 on: 01 August 2013, 00:17 »
Good luck!
Offline Nino
Re: Silicone tip
« Reply #9 on: 01 August 2013, 00:31 »
You will see  :cool:
